Results 1 to 13 of 13
    Established Member Two Rings lask8ter134's Avatar
    Sep 07 2007
    Audi A4 B7
    Whittier,CA
    do I need the Apr fuel pump?
    To go stage 2 or can I still use an autotech or Awe pump?
    Audi A4 Non-Sline 2.0T Fwd Cvt Evo Ms Intake/Apr 91/100/Miltek 200 Cell Cat/Magnaflow Exhaust/Vogtland 35mm springs, Koni Sport Shocks/R8's Replicas w Toyo Proxy 4's/Hawk Ceramic Pads/Front Filler Plate/30% tint/Garmin 760 GPS
    Veteran Member Four Rings Great White's Avatar
    Oct 07 2008
    Pinarello Prince w/Record 10sp
    Raleigh, NC
    Re: do I need the Apr fuel pump?
    I believe the Fuel pump would take you to Stage 2+. As far as I understand Stage 2 is CAI and Exhaust. I don't the brand of the fuel pump would matter if you want to go to Stage 2+
    Active Member Four Rings juggernaut201's Avatar
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    im stage 2 with kmd's it works out fine and feels great lol
    Veteran Member Three Rings 04Ultrasprt's Avatar
    Jan 13 2008
    North NJ
    why stop at Stage 2? lol If you want to stick with APR software and upgrades, go with their fuel pump, although you dont need a fuel pump for stage 2 most companies are starting to recommend it because of the potential for fuel cut in our cars. The APR comes with their software updates and if you ever plan to go K04 or stage 3 through APR youll already be set with the proper fuel pump.
    Previous rides:
    Lotus Elise - B6 S4 Cab - E90 335i - E46 ///M3 - B6 PES Stage 2 S4
    B6 Nogaro S4 - B5 S4 Stage II - B7 A4 2.0T K04 - B6 A4 1.8T USP
    USP CLUB MEMBER #95
    Sep 07 2007
    Audi A4 B7
    Whittier,CA
    I dont plan on going Stage 3, I have a tiptronic and its too costly to have my tranny rebuilt too handle the extra power from what I'm hearing. Stage 2 with all supporting mods, and meth kit and maybe 75 shot of nos should be enough to satisfy my power needs
    Veteran Member Four Rings ElCapitan464's Avatar
    Jul 20 2008
    Orange county
    i have stage 2 and u dont need the fuel pump, the flash is set up for stock fuel pump, but if ur thinking about getting a high pressure fuel pump, than get stage 2+ which factors in the fuel pump which means more horse power which we like
    GONE: B7 S4
    GONE: B7 A4 stage 2+
    FRRG Southern Ring Member
    DUH! an Audi
    los angeles, CA
    as everyone mentioned, you dont really need a HFP, but it helps out and you can turn up boost and fuel higher. If you search, I did a fuel pump thread, that answers some questions and explains problems that people are having with HFP. I stopped updating it, but its pretty good as what it has. If anyone would want me to update it, ill post more information on it.
    -randy
    Veteran Member Four Rings fusionx's Avatar
    May 17 2008
    07 A3 2.0T
    Socal / Boston
    stage 2 is just test pipe / high flow cat
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
    Sep 07 2007
    Audi A4 B7
    Whittier,CA
    well I already have a high flow cat and exhaust, so I just go in to my apr dealer and have them reflash me to stage 2 right?
    May 17 2008
    07 A3 2.0T
    Socal / Boston
    yeah thats all you need for stage 2, the stage 2 software is to prevent fuel cuts and stuff and to eliminate the CEL after your throw on a test pipe / high flow cat
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    APR Stage 2 is simply the downpipe and intake.
    APR Stage 2+ adds their HPFP to the mix.
    These are 2 different programs.
    Contact your software vendor, and see what fuel pump works best with the software you have. HPFP are generally not cross compatible with any software. Software is usually specifically tuned for one specific pump.
    Senior Member Two Rings a4b7smallturbo's Avatar
    Dec 10 2009
    2005.5 a4 b7 2010 q5
    Dade miami fl
    I have the apr fuel pump for sale 750 and its urs email me [email protected]
    got stock exhaust,stock cat,stock air intake,stock sway bar, stock side mounts, priced to sell pm for details
    Veteran Member Four Rings bmc333's Avatar
    Feb 12 2009
    NoVA
    Stage 2 has been discussed to death before - use search!
    If you have a HFC or TP already, the Stage 2 APR program just prevents the CEL/MIL light from coming on - its purely emissions related and give you NO GAIN IN HP. Gains come from the HFC/TP hardware.
    2015 S3 - Panther Black P+ / LED Lights / B&O / APR Stage 1 ECU & TCU / APR Turbo Muffler delete / CTS Turbo Inlet/Discharge/Intercooler Pipes / X34 Intake / Superpro end links / VWR springs / 35% Tint / ED CF rear diffuser / 034 CF engine & fuse box covers / ECS CF battery cover / BBS SR's
