Results 1 to 20 of 20
    Veteran Member Four Rings italia8287's Avatar
    Jul 23 2008
    New York
    need desperate help
    just got the car revo'd yesterday and today im driving and the car starts to stutter. check engine light flashes for a bit then goes off. then i give a little more gas and it stutters again and the light stays on this time. now the car was still boosting so i dont think it was the fuel pump. it almost felt like the car was out of alignment. and it only shook when i gave it gas not when the car was just rolling. i have a feeling it might be a engine mount but would that just be too coincidental?
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Veteran Member Three Rings 04Ultrasprt's Avatar
    Jan 13 2008
    North NJ
    Re: need desperate help
    coil pack went, easy fix. Dont drive the car, just park it. If you can, put it back in stock mode and call your dealer, tell them you "dont know whats going on". If you still have factory warranty they can tow your car in, throw a new coil pack on and youll be on your way in 10 minutes. Or you can just go pick one up for $30 at the same place you got it chipped at.
    Where are you in NY? If youre close I could drop off a coil for you so you can drive it til you get it fixed.
    Previous rides:
    Lotus Elise - B6 S4 Cab - E90 335i - E46 ///M3 - B6 PES Stage 2 S4
    B6 Nogaro S4 - B5 S4 Stage II - B7 A4 2.0T K04 - B6 A4 1.8T USP
    USP CLUB MEMBER #95
    Jul 23 2008
    New York
    Do you think it will be a big deal if I can't flash it back? I don't have a switch. I also need to drive the car, will this cause any harm?
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Veteran Member Three Rings CX-7&A4's Avatar
    Dec 09 2007
    CX-7 AWD/A4
    Foreclosure Captial of the US
    Is the check engine light still on? I'm at 50K and I need to replace the coilpacks I'm sure, doesn't want to start, rpm's are rasing/going down when idling.
    07 Mazda CX-7 AWD
    06 Audi A4 Fail2Trak CVT - TRW Front/Mintex Redbox Rear
    Jul 23 2008
    New York
    Yes the light is still on and the dealer doesn't have an appt available til next tuesday. I think I may just show up tom.
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Veteran Member Four Rings fusionx's Avatar
    May 17 2008
    07 A3 2.0T
    Socal / Boston
    defiantly get it flashed back to stock somehow, maybe you can borrow a switch from someone because the dealer could easily blame the chip to be the problem or something
    07 A3 2.0T S-line - REVO stage 2 - GIAC DSG Flash - AWE downpipe - Custom staggered quad-tip exhaust - H & R springs - H & R sway bar - Neuspeed CAI - fog housing LEDs - VMR boost gauge - JL 12'' Sub w/ Precision Power Amp
    Instagram: @superseany
    CanyonRacerMotorsports
    Project Matte Black: COMPLETE
    Dec 09 2007
    CX-7 AWD/A4
    I would save the dealer visit for another time, the coilpacks aren't that much money and it's IMO not worth the trouble of flashing back to stock for the visit.
    Get a code reader from AutoZone, get some coilpacks, pull the CEL & troubleshoot.
    07 Mazda CX-7 AWD
    Jul 23 2008
    New York
    Quote Originally Posted by CX-7&A4 View Post
    where can i get the coil packs from? i called autozone and they told me to contact the dealer.
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Dec 09 2007
    CX-7 AWD/A4
    You can get them from ECS and the dealer should have some coilpacks in-stock
    07 Mazda CX-7 AWD
    Veteran Member Three Rings Subaru71's Avatar
    Jan 15 2008
    2010 DGM Impreza WRX
    Chino Hills, CA
    I'd pull the code first... it could still be the fuel pump, I've seen it happen.
    2008 Phantom Black TQM
    Jul 23 2008
    New York
    alright ill check the parts department tom. hopefully they have it. keeping my fingers crossed. also how would i go about replacing the coil? is there a DIY anywhere?
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Dec 09 2007
    CX-7 AWD/A4
    Quote Originally Posted by italia8287 View Post
    Disconnect the harness and pull on it, don't touch the metal area.
    07 Mazda CX-7 AWD
    Established Member Two Rings I495 Bandit's Avatar
    Jan 08 2008
    01 St3+VW Jetta/06 A4 S-Line
    NoVA
    Coil packs are really easy to change. Just take the engine cover off and you'll see them. There are 4. Then disconnect the harness that connects to the top of coil (do one at a time) and pull the disconnected coil straight up and it will pop right out. They may be a little hard to pull up at first but they will come out. This is a good time to replace your spark plugs to a 1 step colder plug because you're running more boost and timing with a chip. Then just replace the old coil with the new one. Make sure you push the new coil down all the way until you feel it "click". Re-connect the coil harness and you're done.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    start at autozone and get your car scanned for codes free before you start replacing parts or taking it to the dealer.
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Jul 23 2008
    New York
    how do you tell which one went? will the code reader tell me that?
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
    Jan 15 2008
    Chino Hills, CA
    yes
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    are you guys sure its a coilpack, my PCV did the same thing when it went bad...
    Dec 09 2007
    CX-7 AWD/A4
    Wouldn't be a bad thing to have one just in case, he can pull the CEL thought and see if that's the problem.
    07 Mazda CX-7 AWD
    Veteran Member Four Rings ElCapitan464's Avatar
    Jul 20 2008
    Orange county
    this thread is stupid, k u either have a bad coilpack just go to the dealer and buy them, do it ur self, its a guess and check process, its not that hard, and if ur flashed keep spares in ur car. If its not the coilpack than ur PCV is cracked, do u see oil up on the motor, if u do than ur PCV is cracked which u have to go to the dealership but make sure ur chips off or ur screwed
    GONE: B7 S4
    GONE: B7 A4 stage 2+
    FRRG Southern Ring Member
    Jul 23 2008
    New York
    Quote Originally Posted by ElCapitan464 View Post
    i dont think this thread is stupid, im sure if you needed help this would be one of your options too. got the coil pack this morning and popped it in and the stuttering went away but the CEL is still on, how would i go about resetting it and will that mess with the revo flash?
    2007 QMT6 Ti S-Line
    NorthEastRegionDubs
