Results 1 to 4 of 4
    Senior Member Three Rings riot5alex's Avatar
    Jan 25 2008
    03 3.0QM
    Illvine, CA
    loose fan belt???
    theres a weird high pitched whining sound coming from the fan belt area... (belt behind the radiator i believe. visible when you pop the hood) I hear the sound usually when im in idle, but when i drive off it kinda goes away. Also, theres a burning smell coming from the area that gets noticible when when i stop or park the car.
    Anyone have any ideas? something loose in there? do i need to replace the belt? I just noticed the problem today.
    thanks
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: loose fan belt???
    With the car off, reach down and pull on the belt. It should move but not very easily. Then start the car and see if the tens. has excessive movement, some is normal.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jan 25 2008
    03 3.0QM
    Illvine, CA
    nice.. ok so other than fan belt? anything else could be causing that sound and smell?
    Mar 21 2006
    Lakeland, FL.
    Start there.
    I'm back bitches!
