Results 1 to 15 of 15
    Nov 05 2008
    Roseville, CA.
    Royal Purple Motor Oil
    I going to change the s4 oil for the first time since i bought the car in Oct. I'm considering putting in Royal Purple. Any downside or upside in putting Royal Purple? Also which grade should I put in 5w40 or 0w40. One more thing, can i use any oil filter or can you guys recommend me one? BTW my car has about 59500 miles
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    Re: Royal Purple Motor Oil
    skip RP! it breakdowns quicker than M1 or Syntech. google it.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Active Member Four Rings Goped220's Avatar
    Feb 16 2006
    2023 Audi S4, 2023 Audi A4 & 2016 Subaru Crosstrek
    NY/FL
    I recomened using motul x-cess 8100 5w40. I have used royal purple in the past, motul is better because it has better detergent in it. use either an oem filter or a mann filter from ecs tuning tuning
    Previous:
    2006 Audi A4 Stage 3 6-Spd, 2011 Audi S4 6-Spd, 2016 Audi S4 6-Spd, 2017 Audi A4 6-Spd Stage 2, 2019 Audi S4 Stage 1, 2019 Benz E450 Stage 1, 2015 STI, 2013 370Z, 2013 Benz GLK, 2014 F-150 FX-4, 2020 Lexus GS350 F-Sport
    Dec 05 2006
    So. Cal.
    Yea, shine the RP. I use the Motul's Xcess 5-40 also and it's a great oil. If you wanna go one step better, get Lubromoly.
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    Lubro-Moly 5W40 FTMFW!!!
    http://www.eurosportacc.com/liquimol...nthese_oil.htm
    change every 5K miles and never look back, booyah!
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Nov 05 2008
    Roseville, CA.
    Thanks for all the replies. Unfortunately I cant find any of those Oil mention above around my area. I found some Redline oil, i might be using those. If not I will go with M1. Thanks again
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Just order online. It'll be cheaper than buying it local.
    X? for Lubro Molly! Engine runs so much better now. I don't hear the chain rattle at startup anymore too.
    Mar 01 2004
    2004 Audi S4, 1997 Audi A4 1.8
    Northern NJ
    I recommend any full synthetic you can find locally. Theres minute differences in the crazy good oils, you do get what you pay for, but if youre going 5k intervals, Castrol, M1, theyre all factory fill oils. Just dont push it, I cant stand the newer 15k intervals. Cheap insurance in my mind. Factory filter/equivalent everytime. Dont forget you need 10 quarts.
    Oct 14 2007
    Mammoth Lakes, Ca
    order online, I left the link above...great company, very fast service.
    Lubro Moly FTMFW!!!
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    Quote Originally Posted by channad View Post
    Lubro Moly FTMFW!!!
    How much do you get? 2 of the 5 liter containers?
    /S4
    AWE l Koni l H&R l Hotchkis l VMR l LEDs by fly
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    What does the dealer use?
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Mar 01 2008
    don't most dealers use castrol syntec?
    /S4
    Senior Member Two Rings EssPhore's Avatar
    Jun 01 2008
    2005 B6 S4, 2007 KTM EXC 450
    So Cal./I.E.
    I don't hear the chain rattle at startup anymore too.[/QUOTE]
    At all? Is this the split second "rattling rocks" noise you are referring to? Has this rang true for anyone else? If so, I will make the switch just for that reason, not to mention the other advantages. I cannot stand that noise. Thanks in advance.
    Sean
    Mar 01 2004
    Northern NJ
    I also think the weight will effect that startup noise, not necessarily the oil itself. For it to really stick, and create pressure quicker to stop that rattle, youd prob have to switch to like a 15-40 15-50 weight, which is way thicker than the factory recommendations. Not always a good thing
    Oct 14 2007
    Mammoth Lakes, Ca
    Quote Originally Posted by FastB7S4 View Post
    yes, two of the 5 liter.
