Results 1 to 35 of 35
    Sep 19 2006
    Orange County
    how many miles do coilpacks last
    typically how many miles do the original coilpacks last? Car is an 05 Audi S4
    Senior Member Two Rings fapodaca's Avatar
    Dec 03 2007
    2014 AUDI RS5, 2013 GMC SIERRA, 1989 BOX CHEV
    DISCOVERY BAY
    Re: how many miles do coilpacks last
    No Life Time.......
    Just Carry Spares.....
    Freddie Apodaca J.R.
    East County European AutoWorks
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    My car is an 04 w/ only 23k on it and i had one crap out. When they go, they go.
    If you want to be proactive you can swap them all out at the cost of about $30 per. Some guys that had one crap out while they were under warranty have had their dealerships swap them all out for free. Like the post above said, it would be smart to have one or two in your garage as backup if and when one does go. There are plenty of guys that are running all original coil packs on B6's to this day. Its a crap shoot as to whether or not you will have one or more fail..
    Veteran Member Four Rings 40valve's Avatar
    Mar 24 2008
    khgkhg
    Two of mine failed at 43K and the dealer replaced them all with new version.
    On my old 1.8T I never had any problems with them but know a lot of people that blow them all the time.
    Registered Member Three Rings yakendo's Avatar
    Dec 11 2007
    2005 S4 Tiptronic
    San Francisco
    I have 30K on my S4. Even though Audi say's it is unessisary to change my plugs...I will be doing so this weekend? Maybe coilpacks too? What is the correct part# for b6 S4 4.2 coilpack?
    What is the best place to buy?
    Is the any non oem option that are better?
    Oct 03 2008
    Atlanta BITCHES!!!
    Quote Originally Posted by yakendo View Post
    Audi redesigned the OE coilpacks so there is no need to get an aftermarket alternative. The original coil packs have a black top, the redesigned ones have a gray top. I month or so back i spent $45 for one at the dealer because i needed one asap, but ECS sells them for $30 a pop (best pricing i have seen). If you are seriously entertaining swapping them all out, a $30 DIY plug job is going to turn into $300+ plug and coil pack job real quick.
    http://www.ecstuning.com/stage/edpd/...del=&engine=V8 <-- part # is ES#240938 on their site
    Registered Member Two Rings johnjsb's Avatar
    Dec 14 2008
    88 Licn Towncar and 05 B6 S4
    Bluefield,WV
    Today I replaced one with 47k
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    If replacing a coilpack is a DIY job, how do you replace them? Is there anything I should be aware of prior to attempting a job like this?
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    They just pop out of the spark plug bore in the top of the head. Use a small flat-blade screwdriver to gently lever the connector free. It helps to undo the nuts that secure the wiring loom below the packs. This way you can slide the connectors down and off of the coilpack(s)
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Oct 03 2008
    Atlanta BITCHES!!!
    Quote Originally Posted by Beelzeebub View Post
    I would think there is a DIY on this out there somewhere seeing that its such a common job. The hardest part is being gentile w/ the clips on the back of the coil pack when you are disconnecting them from the harness so that you don't crack/break them.
    Dec 11 2007
    2005 S4 Tiptronic
    San Francisco
    Thank you for the info, link & part number.
    Veteran Member Four Rings oatzel's Avatar
    Jun 02 2004
    LA
    $22 at genuineaudiparts. good to carry one.
    Current: '14 allroad, Premium +, Sport, Black on Black, H&R c/o, Magnaflow exhaust, Hotchkis swaybars, Neuspeed Gunmetal RSe102, CR-15
    '19 s4, P+, Quantum Grey on Black
    Old: '12 4dr GTI Autobahn, Black on Black
    07 s4 avant, ibis, stasis exhaust, vogtland c/o, h-sport rs4 sways, vmr gunmetal v710s, 50/35% tint
    09 A4 2.0t
    03 a4 3.0qms
    00 1.8TQ
    Established Member Two Rings mountainsnbirds's Avatar
    Nov 25 2008
    05' S4 Avant 77' Puch Maxi
    WVU, Morgantown, WV
    Without having the vagcom system. How do you know which pack has gone?
    Oct 03 2008
    Atlanta BITCHES!!!
    Quote Originally Posted by mountainsnbirds View Post
    When mine went bad i was on my way home from work so i just pulled into autozone and they ran the code for me. The code tells you which cylinder is misfiring. From there its either the plug or the coilpack.
    Account Terminated Four Rings
    Jun 02 2008
    2007 S4 MT6; B8 A4 2.0T Avant
    Toronto, Ontario, Canada
    cool info
    I'd love to take a course on familiarizing yourself with the 4.2 V8, so that these jobs are easily doable. I think it costs about 2 hours labour to replace them all...that's $200. If it's really as easy as it sounds, we should all be able to do this stuff.
    anyone know if there is such a thing? I'm sure you can take a class at a school, but not sure they'll have an Audi V8 as the sample engine!
    Oct 16 2006
    Naperville
    86K miles with only 1 replaced (knock on wood) i've owned the car since 23K miles.
    Oct 03 2008
    Atlanta BITCHES!!!
    Quote Originally Posted by sakimano View Post
    cool info
    Back when i had my Z06 my local vette guys and i would have mod days at each others homes a couple times a year. This way we could all help each other w/ projects that we were unfamiliar with that others had done on their cars. we did everything from oil changes to suspension installs. Are there local Audi guys by you that you can do something similar with? If you were local i would tell you to pick up the parts and case of beer and come over but unfortunatley you're not.
    Its really not a hard job at all.
    Mar 24 2008
    khgkhg
    Replace coil-packs? I don't think things can be much easier than replacing them. On 4.2L it's a tight squeeze and you have to remove bunch of little things to get a nice access to them though.
    I'm due to replace my intake filter and spark plugs so I'll write up the spark plugs/coil-pack DIY. You can use my intake filter DIY to help you get to them. After than it's super easy.
    Mar 24 2008
    khgkhg
    Quote Originally Posted by ...Mark... View Post
    That's how it's done. I have never taken any of my cars to a shop to be worked on (not counting warranty/recall stuff). All mods are done by me and my car buddies
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    Mine went out a few weeks ago at 40k.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Depends-
    - how well do you gap and maintain your plugs
    - how hard do you drive your car
    - overall condition of the alternator/electrical system
    A good set can last 60-80K. I just blew two on my Avant that may have had 104K on them.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Oct 08 2008
    B7 S4
    cool. thanks for the info guys. looking forward to a DIY thread on this. (Im a slow learner).
    Dec 14 2008
    Bluefield,WV
    I posted earlier that at 47k well i don't want to high jack your thread but at 47,010 2 more just went out today.
    I should have listened to these guys when they said replace all of them(just do it). I bought 3 of them from 2 different companys 1 showed up yesterday, replaced drove around for a few miles and no problems. Tried to go to work this morning made it about 10min from home, bam 2 more bad(I had my computer/vag in the car). Towed car home, nearest dealer to far away. Did I mention the warranty runs out today. Somebody needs to run a statical analyzes on the probability of this happening the week the warranty runs out. I swear they have a self destruct timer in these things. The other 2 packs are shipping ground and will be here sat. Well I just placed a order for 8 more 2nd day. Now i'll have 3 new spares. $23 ea from genuinevwaudiparts.com. Here is my previous post about this
    http://www.audizine.com/forum/showthread.php?t=254373
    Does anybody offer a discount for a pallet of these things?
    Basically its starting to look like these things are very delicate. I'll take pictures this time to show what has to come apart, will post probably sunday if they show up.
    Veteran Member Four Rings GotRS?'s Avatar
    May 18 2008
    cool info
    A Bentley manual is all you need.
    http://www.bentleypublishers.com/audi
    Senior Member Two Rings blkonblkS4's Avatar
    Jun 13 2008
    Providence, RI
    Quote Originally Posted by surfsidedetail View Post
    Typically between 10 and 100 miles...
    Dec 14 2008
    Bluefield,WV
    Quote Originally Posted by johnjsb View Post
    Well here are the pics hope it helps
    http://www.audizine.com/forum/showth...55#post3215255
    Veteran Member Four Rings V8S4Fun's Avatar
    Jul 22 2008
    05 S4, 95 Jetta
    Taneytown, MD
    Quote Originally Posted by blkonblkS4 View Post
    Ummm...
    [email protected]
    2005 Silver S4
    RAI Supercharged
    Unitronic Tuned
    JHM L/W Crank Pulley
    Custom 2.5" catless DPs w/Milltek Non-Res
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    i have 126k on my 12v v6 and im almost 100% sure they are all stock... haha.
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    oh how true that is. Mine just went out last week. I was under warranty until 50,000 miles. They went out at 50,028 miles...
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Mar 24 2008
    khgkhg
    Quote Originally Posted by earhythmic View Post
    You should still be covered. You could claim that during last service dealer drove the car for 28 miles and you should be compensated
    |^^^^^^^^^^^\||____
    | The STFU Truck |||""'|""\__
    | _____________ l||__|__|_|
    Senior Member Four Rings Bravest NY S4's Avatar
    Jan 18 2009
    BKNY
    here it is....if it'll still help anyone
    http://www.audizine.com/forum/showthread.php?t=255418
    I'LL BE BACK.........
    Never forget SWAY
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    First one went around 25k; and by went, I mean it was fried. Harness and wiring was melted. I noticed smoke coming from under the hood, the CEL flashing like crazy, and the car just died and wouldn't restart. that was fun. waited over 2 hours for the tow truck to come. I asked if they could replace all of them, but they said they couldn't. Well, 9k later, the second one went yesterday at 34k. Luckily, this time the car still ran and I was able to drive the rest of the way home (5 miles). It was towed to the dealer this morning. The service advisor told me hopefully, since this is the 2nd one, they can replace the remaining 6 under warranty.
    /S4
    AWE l Koni l H&R l Hotchkis l VMR l LEDs by fly
    Jan 18 2009
    BKNY
    YEA....stay away from that CRONIC!
    Never forget SWAY
    Veteran Member Three Rings quattro.it's Avatar
    Mar 24 2008
    2004 BMW R1150RT
    Bellevue, WA
    Within the first 12k miles all four of mine have been replaced along with 2 PCV valves. My daughter's B6 A4 has had two colipacks replaced within the first 24k miles.
    2007 A4 2.0T quattro Tip S-Line Titanium / Lava Gray / APR 91 /
    Veteran Member Four Rings ItzDarrellS4's Avatar
    Jul 14 2007
    A Sedan, a Hatch, a SUV, and a Pickup
    The Live Free or Die
    a blew CP's on my 1.8T left and right. havent had any issues on the S4 yet
    mpg's lol
