Results 1 to 15 of 15
Thread: ER Test Pipe Q.
    Jan 18 2007
    Lexington Ky
    ER Test Pipe Q.
    For thoes of you who bought ER Test Pipe who much did you pay for yours? with or with out shipping?
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: ER Test Pipe Q.
    Pass on the ER and get a VMR. You wil save around $100 http://www.audizine.com/forum/showthread.php?t=232238
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    Re: ER Test Pipe Q.
    I like the 3"-2.5" design of the ER if you have a 2.5" DP. Although not the best gradual step down...it is better than an adbrupt step down at the turbo or at the DP flange.
    That being said it is a bit expensive and I'm not sure I would get a new one at the asking price. I got mine used from the classifieds for $125 shipped...although I haven't seen any used ones floating around in awhile.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: ER Test Pipe Q.
    The ER design is flawed, there should not be a step down. The turbo outlet is 70mm (2.75"). VME testpipe is 2.5" ID and there is virtually no bottleneck.
    The ER has an abrupt step down that bottlenecks the gases.
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: ER Test Pipe Q.
    Quote Originally Posted by jessefrank View Post
    even if you have a 2.5" DP it gets bottlenecked at the dp flange also
    - Clint
    Jan 18 2007
    Lexington Ky
    Re: ER Test Pipe Q.
    the ER is 3" on the outlet so thats good for the gases flowing from there, but then that step the gasses bottleneck there and dont flow as well. But then the VMR only being 2.5" and the outlet is 2.75" so wouldnt the gases hit a little right there on the lip? or no? and the stock flex pipe area is 2.5" or 2.75" ? And that being said, the VMR only being 2.5" smaller then the oulet on the turbo and smaller then the downpipe flexpipe (pipe) where it would mate up, wouldnt that restric flow?
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: ER Test Pipe Q.
    There is the tiniest of bottleneck at the flange on a VMR testpipe it is less than 1/8" all the way around, it happens to be where the gasses are hottest (closest to the turbo) so they adapt to the bottleneck much better than the end of the test pipe where they have cooled and densified.
    $100 is still $100 though. You will never notice the difference between the two testpipe but you will sure notice if there are 5 crispy 20s in your wallet.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: ER Test Pipe Q.
    Smokey, "Tweny, Fouty, Sixty, Eighty, a Hunerd...(flips money) a Hunerd Tweny". Big Worm "Nigga...dat's a Hunerd Dolla's"
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jan 18 2007
    Lexington Ky
    Re: ER Test Pipe Q.
    yea thats a good point. Well if i can find one for cheap i will buy it, if not then VMR for sure or have a friend of mine make one. On a side note i should be getting my New Thermal R&D flex pipe piece in some time this week.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: ER Test Pipe Q.
    Quote Originally Posted by 400HPA4 View Post
    LOL, you might want to read the thread before you post it.
    Quote Originally Posted by VMRSport View Post
    Sorry, still out of stock. We only have the heat shielded test pipes in stock at the moment.
    thanks.
    -Don
    Your link is FLAWED
    Mar 21 2006
    Lakeland, FL.
    Re: ER Test Pipe Q.
    Goodbye.
    I'm back bitches!
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    Re: ER Test Pipe Q.
    i tried to buy a VMR test pipe yesterday but they are out of stock.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Jan 09 2006
    Rapid.City
    Re: ER Test Pipe Q.
    There's always ebay...
    Used to be quite a few no name B6 TP's on there for about 100 shipped (as long as the welds are decent...a piece of pipe is a piece of a pipe!)
    Did find this one though (although it's 3"):
    http://cgi.ebay.com/ebaymotors/ATP-T...Q5fCarQ5fParts
    And there are the classifieds...saw a PSI TP not too long ago (http://www.audizine.com/classifieds/...ct=6703&cat=12)
    I actually have a ATP TP sitting in my garage I got free with my AWE exhaust. Figured I'd save it incase I get a 3" DP put on the AWE Cat back.
    ...well for the time being I guess I'll stick by my flawed ER TP . I really don't want the step down at my DP flange gasket.
    Jun 03 2007
    california
    Re: ER Test Pipe Q.
    that fits the stock KO3 for B6 right? Does the 3 inch actually not benefit the stock turbo since the pipe is bigger than it needs to be the 2.5 like the vmr is the right size?
    Jan 09 2006
    Rapid.City
    Re: ER Test Pipe Q.
    Both...yes, B5/B6 A4 1.8t's.
    The PSI is 2.5" throughout while the ATP is 3" throughout.
    I know the turbo out let is bigger than 2.5" and smaller than 3" (not 100% on exact size)...Greg stated it's 70mm
    IMO either a 3", er 3-2.5, or 2.5" is way better than the cat (well except at cleaning the air ).
    Depending on what exhaust you have I think the 2.5" or ER is best for stock thru 2.5" downpipe aftermarket exhaust as the 3" puts a big step down right where there is a gasket (downpipe-test pip gasket) which IMO can cause premature failure. I've read before of some having this issue w/ 3" TP on a stock exhaust.
