Results 1 to 7 of 7
    Senior Member Three Rings audihtp's Avatar
    Sep 28 2007
    Levittown, NY
    question on engine swap
    mine 99 with 2.8L
    those 2.7L turbo will go in without any problem? what are the parts needed to swap engine? just curious since I've been seeing some 2.7L engine available for around 2~2.5K so I was just thinking get it, fully rebuilt then swap motor in.
    it will be after my first project gets done, so long project, just curious what needed to get the job done..
    Jun 01 2008
    Apopka, FL
    Re: question on engine swap
    You need, the engine, engine harness, the stock 2.7 or an aftermaret exhaust, and the ECU, everything else is a direct swap. However, the above is much easier said than done. It would be better to sell the car and buy one with a 2.7.
    Apr 18 2007
    ny
    Quote Originally Posted by blmlozz View Post
    +1
    6 Speed--EPL--034--SPEC--ER--AquaMist--Forge--RS4--RS6--K04 --RNS-E--DTS--PSS9's
    SOLD
    Greg
    C5UNION
    Nov 19 2005
    Pair of (. )( .)
    mount points are the same , but there is more involved.... if money is not an issue then do it.
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Senior Member Three Rings TWINTURBOA6's Avatar
    Nov 20 2005
    Audi A6 2.7T Quattro + more : )
    Rockville,Md
    damn that's going to be a lot of work
    Audi D4 Technologist
    Audi Exclusive Service Consultant
    Join us at WWW.QUATTROKINGS.COM for more AUDI excitement!
    Sep 28 2007
    Levittown, NY
    yeah right now I seen 2.7t around 10k and thought about sell 2.8 and buy it. but if I do it this way, I can built the engine way I want to get it done, (stage 3 etc) and send it to have engine swapped later when my truck is running (it wil run now also but few things needs to be done to get my air suspension so it rides better). so I don't end up with no ride. it's a thought though I'll look on bentely book and see what are exactly needed, then might change my mind and sell mine out, then get 2.7t..... or TT(lately in mind also if I'm selling 2.8 I have now....)
    thanks for the info. now I can start research a bit and make my decision on it.
    Active Member Two Rings rlzx76's Avatar
    Dec 30 2008
    S6 ,b5 as4 ,s4,q45 cima
    Philadelphia
    I have done that swap a few times You will need engine, trans, ecu, rear diff ,axles and spindles
    drive by wire pedal if your car is not equipped with one already and chassis wiring harness or you can splice in the wiring if you know what your doing
    Its much easier to have a donor s4 to swap every thing over
    My shop is located in philadelphia if you need some help on the swap ,rick
