Warning, it's semi long.. I'll put each section in bold if you want to skip to a certain part.
Introduction
I went the least expensive route of trying to eliminate the engine/transmission slop found on our b5's by replacing my snub, engine and transmission mounts with much stiffer and highly recommended mounts. They made a great improvement, but I wasn't satisfied. I could still feel plenty of movement, not only on spirited drives but just driving around the city. I know many people wouldn't notice and most of those that do probably wouldn't care but not me. It bugged the shit out of me, like many things with my car that I know should be better.
I was very skeptical about buying the AWE DTS bar after reading some other reviews that noted little or no noticeable improvement, but with the holiday sale pricing the bar at $252 shipped (ends the 31st of Dec) compared to the $350 regular price, I decided to take a chance. I bought my bar from Jeremy@Matrix (www.matrixintegrated.cc).
Many of the reviews I read recommended buying the Energy Suspension Transmission Mounts - noting that it was much stiffer than the one AWE included. I bought mine from Summit Racing for about $25 shipped. You won't need the backing plate or bolts that come with this, the ones that come with the AWE DTS works just fine on the a4 (you'll apparently need to buy a couple bolts for the s4).
Installation.
Before the install I applied a few layers of clear coat on the bar and backing plate to help keep it looking good.
The install was very easy and straight forward, but like with everything else you're doing for the first time (or first few times for somethings), make sure you read the instructions. It's pretty much unbolt the old bar and bolt the new bar.
As you can see, it looks ten times better than the old stock bar. In retrospect, I should have taken a picture of their thickness. The AWE DTS bar was roughly four times thicker than the stock bar. What I liked about AWE DTS bar so far is that it connects to the transmission, unlike the stock bar.
This picture shows the Energy Suspension mount and the AWE backing plate.
The install didn't take more than an hour with all the proper tools.
Here it is installed.
the Test
Just putting my car into reverse to back off the car ramps, I noticed a difference. Everything felt much more intact. Also, no added vibration. In fact, the slight vibration I felt with the upgraded mounts has very slightly diminished. So far I'm impressed, but not $252 dollars impressed.
I take the car for a spin around the city and I no longer have movement when I completely release the clutch in a low gear at a high rpm. I take the car out for a 20 mile drive along route 2 and some top secret roads I like to drive on - I do a couple 3-4k rpm launches and the car feels completely solid. Driving around I'm shifting a thousand more times than necessary, just trying to get some movement out of my drive train and I can't.
Had I known it would have been like this I would have shelled out $350 and bought this long ago.
In conclusion
It works as advertised and I'm very happy. A little expensive, but worth the money, If you're staying stock (k03/k04) you could probably forgo upgrading your stock transmission and engine mounts (minus the snub) assuming they're in good condition - I'd just buy a stiffer snub and bracket, coupled with the DTS bar.
If you've already bought this and didn't notice much of a difference, I'd recommend trying the polyurethane transmission mount over the AWE rubber mount @ summit for about $25
If you have no drive train issues, save your money. but if are bugged by the sloppiness still felt even with upgraded mounts. it's worth the money.
10/10 with the Energy Suspension mount.
Additional Pics (30Dec08)
Here's a weak comparison of the thicknesses of the stock bar vs the AWE DTS.
Here are a couple of pics in hopes to give you an idea on how much clearance I've got. This is with the stock sport height. Ground to fender, I measured 25 3/4". From the bar to the ground I measured 4 1/4"
