Results 1 to 7 of 7
    Veteran Member Four Rings palewhitemale's Avatar
    Sep 22 2004
    MT
    running rough... need ideas.
    ok, so I'm currently running a K04 with REVO, see sig for the rest.
    The car idles fine, and runs fine at full boost. However, when I'm just barely on the throttle it is rough as hell.
    It isn't: MAF, symptoms exist whether or not it is plugged in.
    Plugs: running the Bosch ones that Ecode recommends
    Coils: brand new set in today.
    anybody have any ideas?
    Oh, right... I'm also in Montana visiting my dad for christmas and trying to leave for portland tomorrow, which doesn't look like it'll happen, but either way, I need to get home to LA.
    Thanks for any thoughtful responses.
    -bill
    2003 RS6 Avant, Goodwood Green/Black - Stock
    2018 Q7 Prestige, Glacier/Cedar - Stock
    2015 Q7 TDI Prestige, Carrera White/Espresso - Totaled @ 25k miles
    2015 Q5 TDI Prestige, Scuba Blue/Chestnut - Stock
    2001.5 S4 Avant 6sp, Stg III, Casablanca/Silver - SOLD
    2008 RS4 Avus/Black - SOLD
    2012 A3 TDI Monza/Black - SOLD
    2003 RS6 Sedan Avus/Black - SOLD
    2004.5 A4 Avant 1.8t - SOLD
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: running rough... need ideas.
    Carbon build up on valves.
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    my god its pale white douche nozzle :)
    what up brotha!?
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Sep 22 2004
    MT
    greg... you being sarcastic or serious?
    if that's the case, am I looking at a full valve job to fix the problem? Also, should it not be driven until the problem is taken care of?
    thanks,
    -bill
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    You can probably run some water through the intake and clear it up. This is how Sarabi described how to do it to me...
    1.) Remove a vacuum line to the intake.
    2.) Use something to spray the water into the intake (bug sprayer works good)
    3.) Rev the motor to 3500-4000 RPMs and add the H20, the car will try to die if it does quit spraying.
    4.) Do this for about 10 minutes.
    You could also do seafoam.
    Mar 31 2004
    CA
    hahahah
    Sep 22 2004
    MT
    thanks for the info greg.
    charlie, you continue to be useless. Carry on.
    -bill
