Results 1 to 7 of 7
    Nov 22 2008
    01.5 S4
    Michigan
    Thumbs down (Video) Weird Light Problems
    So my fuse and battery light always come on and even when i change the fuse they just keep popping.....so my radio lights dont work and when i open the rear doors the lights just blink i got a video of it...its not the best quality(phone)....so has anyone had this problem please tell me what is going on cause this is really bothering me ...thanks
    http://www.youtube.com/watch?v=i2b7hLU5t78
    Jun 01 2008
    Apopka, FL
    Re: (Video) Weird Light Problems
    if you keep poping fuses, it means there's a short somewhere, plain and simple..check under the dash at the grounds and terminals and make sure they're tight, other than that it's hide and seek with the wire diagram.
    Registered Member Two Rings
    Nov 27 2008
    Audi R8 5.2 L V10 :)
    Michigan
    bump
    Nov 27 2008
    Michigan
    You people serious...114 views and only one post. Wow.
    Nov 18 2008
    2018 Passat R 1999 A4 2.7t stg 3+ 2019 Tiguan
    Chicago
    Did you try using vagcom? Bad battery?
    Go BIG or GO HOME!
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    sounds like a short somewhere, that is why the fuse keeps popping.
    Have you done any modifcations to radio or wiring in the car? I would try checking there if you did.
    Another thing you can try is the wiring in the doors, or which ever door causing the flashing light. Sometimes from doors opening and closing a lot from age the wires that are in the rubber by the door hinges can get brittle and brake, sometimes causing shorts, or what I've seen more is power windows not working correctly.
    Hope that helps.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Nov 22 2008
    01.5 S4
    Michigan
    shit i gotta check everything out and illl get back to u guys thanks
