Results 1 to 14 of 14
    Feb 17 2008
    Question H&R, vogtland or stasis coilovers?
    Which ones and why? Looking to buy a set for my daily driver 02 1.8T quattro 5spd. I do not want a slammed look. I have read vogtlands are easiest to adjust and I also know that the h&r's are the cheapest and can be had under $1000. I just want to drop the car a little and drasticly improve my handling. I will probably be adding a rs4 rear swaybar as well.
    02 Audi A4 1.8T Dolphin Grey Pearl 5 speed Retro Solutions HID Podi boost gauge Stern snub
    92 Mustang LX 347 stroker
    Veteran Member Four Rings bryzf1's Avatar
    Nov 24 2007
    New Mexico
    Re: H&R, vogtland or stasis coilovers?
    surely this has been covered several times
    Jan 17 2008
    05 A4 QMT6 USP Moro Blue
    My Vogtlands are great, nothing super impressive but they do the job, probably the same as stassis and h&r. Adjusting is really easy, even a monkey could do it. Right now for winter I have them set up at the highest possible and its still way too low for winter driving.
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    I have read that you can't adjust dampening on H&R coilovers. If this is a concern to you, you might want to lean towards a different set.
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    vogtlands are pimp
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Quote Originally Posted by 4Rings3Liters View Post
    H&R coilovers don't have damping adjustments. They are fixed dampers, height adjustable only.
    Mar 27 2008
    04 Audi A4 3.0
    North Jersey
    stasis
    Veteran Member Three Rings tdmopar59's Avatar
    Jun 23 2008
    05 A4q 1.8t 6mt
    this would prolly be a lot better if it was a poll....
    05 1.8t 6mt | itg filter | bailey dv | UNI flash | USP front | e-codes | stay tuned
    help me buy more parts!! Any work you need in SE PA area on your car or with construction let me know!! (PM me)
    Veteran Member Four Rings gotboost's Avatar
    Nov 04 2007
    Minnesota
    Stasis FTW
    Current:
    2002 A4 Avant - Eibach Pro Dampers | Rev Motoring Springs | 034 Motor Mounts | 710N DV | Apikol Snub Mount | 18" S4 Peeler's
    2001 Imola S4 Satge 2+
    2003 A4 GT2871r 303 AWHP 291 AWTQ
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    STaSIS does not make coilovers...
    In the same pricepoint as the Vogtland and H&R are the Koni 1150 (the set that STaSIS rebadges and sells)
    You can find them for a very good price typically at PureMS, MJM Autohaus and other AZ supporters.
    In my opinion, you should save up a few more dollars and get the STaSIS/Ohlins SL, it is a great setup, they are asking $2499 but I am pretty sure there is some wiggle room in there.
    If you go with a setup that costs $1000-1200 they will not last >50K miles.
    Mar 06 2005
    San Jose, CA
    ^my vogtlands were less than 1k and theyve been on for about 50k, they feel fine.
    USP CLUB MEMBER #10
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    H&R
    High speed Ferrari movement...
    Feb 17 2008
    I don't think i'm too concerned with adjusting the shocks/struts. I just want a nice quality piece thats going to make a huge difference in handling while being good enough for a daily driver on new york roads. I do not want it slammed.
    Jun 23 2008
    Are the Vogtland or Stasis stainless steel?
