Results 1 to 15 of 15
    Sep 08 2008
    2K S4+79Merc300SD+65Barracuda
    Rohnert Park CA
    How To? Run w/no DPs
    Because of the core exchange and the 70mile drive(one way), I heard I could drive without exhaust from the turbos back. This is illegal but dont want to shell out $$ and drive twice. Something about disconnecting the MAF. Can someone confirm this. It was also stated, by APR, that the O2s dont need relocating, just a new file on the ECU. Guess its just a gutted DP with no need of defoulers? Any way, this is a planned tax return project.....plenty of time to sort this out.
    Veteran Member Three Rings AudiHolicS4's Avatar
    Apr 16 2008
    Pasadena, MD
    Re: How To? Run w/no DPs
    well apr can tune out you rear o2's but as far as i know its only for stg 3 tunes unless you can tune yourself than it wouldnt be a problem i could be wrong about that im a noob to audis so best of luck
    2000 Silver S4
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    You could run about 2 miles without dp's before you melted something. Look where the turbo's exit, you don't want 900 degree exhaust gas blowing there.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    I would just have them shipped. For 70 miles, it shouldn't be to outrageous.
    B5 S4 AWE Stage 3 - sold
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by RolledMySTi View Post
    I melted a hole in a SAAB 900 gas tank from running without a full exhaust..not even a turbo..
    08 S4- Stock SOLD
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    lucky you didnt ignite anything.. yeah the turbos exit facing the rear of hte car, but they point directly at the car, not down. youd melt something for sure
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Aug 06 2008
    Canadia
    not to mention boost creep.
    see if they will do a collateral instead of a cash deposit
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    i bet you would get a tonnnnnnnnnn of compressor surge too.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    ill sell you a set of piggies cheap so you dont have to go without downpipes, but you will have to meet me half way from sac
    http://www.audizine.com/classifieds/...p?product=6804
    Veteran Member Four Rings KompMan420's Avatar
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Mod right or do it twice!!!
    If you can't afford to do it right the first time what makes you think you'll be able to afford to do it the second time? Just some friendly advice from the guy that's learned these lessons the hard way...
    SOLD - 2001.5 Audi S4 Twin Turbo ~ 450hp
    Mods - AWE/GIAC Stage 3 | AWE Intercoolers | STaSIS Coilovers | RS4 Clutch | 3" Borla Cat-Back | ASP DTS | JHM Solid Axles | "Piggie" downpipes | Neuspeed SS | AWE Pedals | IceLink for iPod | 710n DVs | M3 Spoiler | LM Reps 18x8.5 Satin Black w/red Time Attack
    www.NJSRealty.com
    Sep 08 2008
    Rohnert Park CA
    Waiting for response to used piggies for sale! Otherwise I'll have to pay more $ for new + core.
    The re-flashing eliminating rear O2s.....will I get CEL?
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    no. when you reflash to eliminate rear 02s the CEL won't come on because the 02 sensors are no longer in use. If you relocate the 02s or use defoulers then you won't need a reflash and your 02s will still be functional and serve their intended purpose. I'd just buy used piggies to save the time and effort. there are piggies and ssac DPs in the classifieds all the time for 100-150. Sell your stock DPs and have a local member help you with the install for some beer. I would imagine the shop is charging far more then $100 for this mod.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    you dont need secondary o2's and you dont need the apr file to eliminate them. zip tie those ******s up to your transmission and drive with open dumps/down pipes. a lot of people do it this way, me being one of them. its not too loud outside but inside the car wow.. ear-rape
    i hope youre not asking about running without downpipes lol.
    Sep 08 2008
    Rohnert Park CA
    Ah! So the re-flashing wont add power, its only the flow that does? When I get the used ones I'll just do it myself.....There are no local Audi groups, but I like being alone. I want to head up to 2Bennett anyway to get race file and some parts, so we'll see if they re-flash for free so I dont have wires hanging around.
    Oct 08 2008
    MA
    This should help if you want to relocate your 02s...even if you buy used with relocated 02 sensors, this should help. There are some tips for making the wires reach farther back on the DPs: http://www.audiworld.com/tech/eng75.shtml
    Or get 2 defoulers from vast if you don't want to weld:
    http://vastperformance.com/shop/prod...products_id=68
