Results 1 to 3 of 3
    Veteran Member Three Rings midn12ght's Avatar
    Jun 17 2004
    socal
    will 17" or 18" A3 OEM wheels fit an A4
    ...or an A4(b6) with b5 s4 brake setup with 10mm spacers?
    You mustn't be afraid to dream a little bigger darling...
    Feb 22 2008
    ma/ct
    Re: will 17" or 18" A3 OEM wheels fit an A4
    not sure about caliper clearence but i use 17" a3 wheels with 12mm spacers for winter wheels on my a4. i belive the offset is 56 so you'll probably need some wider spacers(15 or 20).
    Jun 17 2004
    socal
    thank you so much! i don't want to run any spacer upfront larger than a 10-12 setup. couldn't find an answer anywhere...
