Results 1 to 10 of 10
    Veteran Member Four Rings Rommulus's Avatar
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    First CEL... Coilpack?
    So, I'm driving home for lunch and out of nowhere, my CEL comes on and the car begins to shudder while i'm at a complete stop and idleing. When I tried to accelerate, the car acted as if it wasn't getting enough gas and was going to stall. I made it home (only 2 miles) but something is clearly wrong and i don't want to drive the car until I figure out what's up. With the car parked and running in my driveway, the exhaust sounds like a helicopter when you get close to the tail pipe.
    Did I lose one of my coilpacks? Could this be a problem with the fuel injectors? I hoping some of you guys with more engine knowledge can help me diagnose the problem quickly. Thanks!
    Established Member Two Rings articONE's Avatar
    Apr 28 2008
    nj
    Wink Re: First CEL... Coilpack?
    same thing happen to me christmas eve its a coilpack. with the car running disconnect each coil 1 by 1, when u disconnect a good one u should notice a change when u disconnect the bad one u will not see or hear any change.
    Veteran Member Four Rings zz2h33's Avatar
    Jul 28 2008
    2002 Avant 3.0L
    Chicago, IL
    ^x2 sounds like a CP.
    02 Avant 3.0 // Avant Garde Member // 3.0 Group Member
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Is the dealer the best place to get a coilpack? How much do the usually cost? Is it really ok to change them with the engine running? Thanks for the help guys!
    Apr 28 2008
    nj
    dont change them while running. u can just disconnect the harness that goes to them while the engine is running to see which one is bad,but make sure u do it 1 by 1. it wont harm ur engine it will just cut off spark to ur cylinder just like the problem u have now. i was in A pinch so i got one from napa but im goiing to change it out with a better one. it was 35$ from there.
    oh yeah mine was broke in half so it might help to have some needle nose pliers
    Aug 29 2007
    '03 1.8TQM
    Portland, OR
    Thanks for the help articONE! I replaced the CP and that did the trick. However, the check engine light is still on. It's no longer flashing, but remains on. Do I have to have the car vag'd to get it to turn off? Thanks!
    Veteran Member Three Rings Kerschera4's Avatar
    Jun 21 2007
    DC
    Quote Originally Posted by Rommulus View Post
    any auto parts store like autozone or advanced will clear your codes for free if you dont have a VAG
    Senior Member Three Rings Sp3C14L 3D's Avatar
    Aug 17 2008
    2005 A4 1.8T Ultrasport
    Yes your one of your coils went out, i had the same problem last month! Plug in an OBD2 and it will tell you which cylinder is misfiring.
    USPCLUB MEMBER#724
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    the cel will go off in 3-5 drive cycles if the pcm does not see a problem
    Nov 21 2008
    02 A4 1.8TQT, 00 Jeep GC V8
    So weird...my wife drives the Audi most of the time and she called me today with the exact same problem. I looked on here and this was the first thread on the page earlier. I did the test and sure enough, I have a CP out.. replacement at Autozone was $32 and I will have in tomorrow AM. Awesome that it is so easy to do too
    2002 Black on Black B6 1.8TQ Tiptronic
    APR 1+ with TT225s/Exhaust/TIP/Snub
    Carbonio intake/Hyperboost DV
