Results 1 to 13 of 13
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Need a part from Europe
    I'm trying to locate a source for the bracket that relocates the Secondary Air Injection pump to the necessary position to utilize the passenger's side side-mounted charge cooler that the Europe market cars come equipped with.
    I don't know which countries in Europe/UK use the Secondary Air Injection system. I imagine that with Europe's strict emissions laws this is standard equipment on most cars.
    My car is a 2003 1.8T car. If someone could help me with this transaction I'd greatly appreciate it. I would be glad to buy it from a dealer if they will ship it state-side. I don't speak any other language other than some Spanish so I would need to talk to someone who can understand me.
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Sep 22 2008
    2004 A4 1.8TQM Sport Package,
    CT - USA
    Re: Need a part from Europe
    Quote Originally Posted by AudiOso View Post
    Ever cross your mind to try audi spain?
    That's europe also isn't?
    http://www.audi.es/audi/es/es2.html
    Good Luck
    2004 A4 1.8tqm 6 on the "Left Leg"//Lower Painted//Tinted 20%//Synapse Synchronic BOV//Debadeged//S4 Bi-Xenon eCode Gray Housing 6000K//K&N Air Filter//Magnaflow Exhaust// RNS-E//OEM Bluetooth//APR Stage 1+//RS4 Sway "energy" Bar//RS4 Caliper Brakes//VMR V710 19"//RS4 Pedals//STaSIS Street Sport//A.W.E Vent Gauge//Helix L.E.D Tail Light//Evolution Raceworks TIP//Black Glossy Vinyl Roof//EuroCode FMIC//6000k Fog Lights//Caractere Front Bumper//Deval Front Bumper Splitter//
    Veteran Member Four Rings AvanTTix's Avatar
    B9.5 Q5 55 TFSIe, B6 A4 1.8T Avant, MKI TT 1.8T 225hp Roadster
    San Francisco, CA
    If you can figure out what the number of the part you're looking for from this diagram, then you can call WorldImpex for example and ask them if they an get it for you. I was able to order #24 from them as mine was starting to tear in half.
    MY2024 B9 Q5 55 TFSIe: GlacierWhite||7-Speed S-tronic||Prestige||Black Optic||Sport Plus
    MY2003 B6 A4 1.8T Avant: DenimBlue||Ebony||5-Speed MT||Quattro||Premium||Sport
    MY2002 MKI TT 1.8T Roadster: BrilliantWhite||RedAmber w/ Baseball Optic||6-Speed MT||Quattro||Premium
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Hello Stéph... I pm'd you about this. Unfortunately, the illustration does not show the Secondary Air Injection System. I think that the pump is shown with related emissions parts. Do you have access to the catalog page for those components? - Miguel
    San Francisco, CA
    Which part(s) are you missing from this:
    These are all the parts needed to retrofit a DSMIC.
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Stéph... I'm missing parts circled in the picture.
    San Francisco, CA
    Here... the search is your best friend...
    Quote Originally Posted by 400HPA4 View Post
    These are all of the current part numbers required...some of the items can be sourced in the USA (clamps, screws) the rest have to be purchased in Europe.
    8E0 145 806 F CHARGE AIR COOLER
    8E0 145 814 B RETAINER
    N 902 218 03 ALLEN KEY HEAD BOLT (4)
    058 145 824 A GROMMET (4)
    050 129 669 GROMMET
    8E0 117 336 C AIR GUIDE LEFT
    8E0 145 845 D PRESSURE HOSE
    N 105 188 01 PIPE CLIP (2)
    8E0 145 686 C PRESSURE PIPE
    N 907 397 01 PANEL SCREW (4)
    8E0 145 832 AH PRESSURE HOSE
    06B 145 712 L AIR CIRCULATION PIPE
    N 904 898 01 CLAMP (4)
    06B 145 712 N AIR CIRCULATION PIPE
    035 133 989 C INTERMEDIATE PIECE
    06B 906 615 A SMOG PUMP BRACKET
    8E0 133 889 G CONNECTING PIPE
    06B 133 817 AC CONNECTING PIPE
    06B 133 607 C CONNECTING PIPE
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Stéph... thank you so much for the parts list! Is there a site where I can compare the part numbers to the illustration? I need to know which hoses I am ordering. Thanks!!!
    Nov 09 2007
    Australia
    From what I can see,
    i will try find the other parts using my ETKA tonight.
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Stéph... did you have to change the pipe circled in this illustration to convert to the DSMIC?
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    That circled part (15) stays put then 7-13 is removed and replaced with the shorter "U" shaped red circled part located in the lower middle third of the table in post #6. This is bcs the pump is moved directly onto the engine block closer to 15. I bought a second hand kit and that piece was missing so I used the boost reservoir hose to connect the smog pump to "15"
    I'll add a pic here in a lil bit....
    If u look closely u can see the bottom of "15" connecting to the smog pump with my old boost reservoir hose fabricated in there with different hose ends. Also visible here is the tiny K03 turbo outlet and the smog pump.
    Here is a slightly different view of the same thing.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    So "8" is eliminated when doing this conversion?
    May 13 2008
    NoCal - EBay
    Yes, matter of fact I used the ends of "8" to build my fabricated hose.
    Ohhh and be very-very careful with the squeeze ends on the emissions/smog pump hoses they are very fragile and only need a little pinch and pull to remove if done right.
    'SOFTWALKER MODS
    Avant>Sedan! Click
