17548.P1140
Bank 2 (this is my passenger side, right any DIY)
Sensor 2 Internal Resistance
16544.p0160
02 Sensor Circuit Bank 2 (im assuming cause the code up top)
No Activity
17947.P1539
Clutch Switch Input Circut-F36 Implausible
01435.
Brake Pressure Senser -1-, G201
What is this??
Swapping out Dot 5 for Dot 3 or 4 Today.
00787.
Fresh Air Intake Temp Sensor G89
00792.
Air Conditioner Switch
01206.
Ign. Time Period Signal Off
01039.
Coolant Temp. Gauge Sender G2
00849.5
Contact On ignition Starter Switch.
the ones im worried about are the
The Coolant Temp Sender, the Clutch Switch, Air Conditioner Switch, Brake Pressure Sender.
