Results 1 to 12 of 12
    Veteran Member Three Rings VinNyS4's Avatar
    Nov 07 2007
    New York City
    shifter wobbles!!
    My shifter in my S has been wobbling for sometime now and now its really pissin me off. When I get on the throttle the shifter will move back and when I let off it will jerk forward a little. Sometimes right when I let off (example half throttle) it kind of feels like the car is bucking for a second. Is it because my tranny mounts? I about to pick up some 034 track density mounts but I dont want to buy them and its not the problem. Thanks in advance.
    10 b8 s4 6MT sprint blue / black & silver
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: shifter wobbles!!
    Could be the tranny mounts, but even new, these cars had rocking shifters..they are heavy trannys. A DTS will help too.
    08 S4- Stock SOLD
    Veteran Member Three Rings Kerschera4's Avatar
    Jun 21 2007
    DC
    your motor mounts may be going bad
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    can you identify whether it is your shifter itself or your transmission? pop off the center surround / unscrew the sound deadener, and see if you can identifty anything moving by itself in the shifter area. that stock plastic ball on my shifter moves around where it is seated, making shifting kind of sloppy. it moves when i get on it, not much, but it does.. But so does every other manual car i've ever driven.
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    My shifter has always moved forward/back when I got on and off the accelerator. Even when practically new.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Feb 17 2008
    Ottawa Ont.
    its a solid linkage, not cable. Physically impossible to completly eliminate the movement without also eliminating trans and subframe mount movement.
    IE solid mounts. And by solid, I mean delrin or metal.
    Registered Member Two Rings Giza's Avatar
    May 14 2007
    B5 S4
    Encinitas, CA.
    i have trany mounts and mine does the same thing
    Jun 14 2007
    2000 S4
    Connecticut
    When I changed from stock to 034 Track Density motor and tranny mounts that helped a ton, but the last piece to the puzzle is the rear diff mount I heard from Apikol to lock it up some more. I wouldn't do a DTS just because I already have to worry about scraping my exhaust I don't want to scrape one more damn thing on my car!
    Nov 07 2007
    New York City
    Alright so i guess getting the new tranny mounts wont really help much. As long as it normal for these cars and everyone else is having the same problem I guess its fine. I just dont want to keep driving the car and its not normal.
    Jul 07 2007
    Tempe, AZ
    make a video
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    I used to have that clunk too. 034 Snub + CAGE and JHM spacer kit and an A.W.E. DTS with the JHM poly mount upgrade eliminated 90% of it. I am on stock motor mounts as well.
    That is the secret recipe.
    You also need to check if your rear diff mount is broken too. That will cause a clunking. I just upgraded to the Apikol rear diff mount and everything is very solid now. Car launches VERY clean.
    We sell all these products in our online store.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Established Member Two Rings s4Xcelence13's Avatar
    Nov 15 2008
    Stg II+
    Dirtee Jerzee
    It depends on the amount of movement, if its a great deal, then it might be your transmission, but if its a small amount, its inevitable because its awd and the way trans is located.
    /_/// GIAC-Xr /_/// SSAC DP /_/// AWE-TWIN 1 CB /_/// FORGE MB /_/// FORGE 007 /_/// RS4 CLUTCH & FW /_/// AWE BOOST GAUGE /_/// 18' RS4 RIMS /_/// STAGE 1 STOPTECH BRAKES /_/// SSP Transmission Rebuild /_/// JHM FMIC /_/// JHM SS /_///
    "I have a love-hate relationship with my S4. I feel safer on a racetrack than I do on New Jersey's freeways."
