Results 1 to 28 of 28
    Nov 23 2006
    "I'LL SHOW YE GARAGE!"
    Soooouuullllll Cal!
    Questions to people who have testpipe w/ flash.
    Has anyone had a flashed/chipped program with testpipe that passed emissions?
    If not, did anyone use non-fouler mod just to pass emissions?
    kthxbai.
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: Questions to people who have testpipe w/ flash.
    I live in Florida, and we don't have inspections anymore. I know this doesn't answer your question, but I'm flashed with the APR test file to prevent the check engine light. Based on how my exhaust smells now, I don't think there's any way that my car would have passed an emissions inspection - they used to stick a pipe up the exhaust.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    I don't think that it'll pass either. You'd be better off finding a shady smog tech.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Buncha motorcycles
    Memphis, TN
    Go with Benjamin Franklin, he is pretty persuasive
    if they just do a the OBDII test, it will pass, if they use the sniffer, it may fail (well probably will fail)
    APR Stage 2/AWE Intake
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    not possible to pass without a catalytic converter on literally 98% of cars.
    Dec 25 2004
    Earth
    Your car will not pass inspection, especially if they connect to the cars OBD port.
    The car will actually dime itself out, and fail the readiness test, with a test pipe.
    Tuners like Revo and APR offer software to keep the CEL light out, but it doesnt alter the readiness test.
    Anti-foulers dont work because the front oxygen sensor reading will not differ from the rear sensor,(test pipe doesnt clean any exhaust) with the foulers, and again the car will fail the readiness test, and give a 02 sensor code. This may cause the State Inspector to wonder why your car doesnt show a CEL, and they will see the test pipe where your cat once was.... Its a Federal Crime, which carries up to a $25,000 penelty to remove emission equipment from your car...
    Best advise I can give is get the Milltek HFC, as it flows like a test pipe, however will pass emissions/readiness/inspection. I have one on my A4, because I got tired of swapping out my test pipe every year...
    Nov 02 2007
    SF Bay Area, CA
    Quote Originally Posted by MikTip View Post
    every year? isn't it every 2 years?
    Nov 23 2006
    Soooouuullllll Cal!
    darnit. Oh well, I guess I'll have to be one step ahead of the emissions test.
    Miktep, I also searched that HFC can also cause cel.
    Buncha motorcycles
    Memphis, TN
    there is a relocated HFC made by someone too. at least you wont have all the heat being held right at the turbo
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Quote Originally Posted by pandaudi View Post
    Depends on which HFC. I have not heard of a Milltek ever failing an emissions test or throwing a CEL. The same cannot be said for other vendors.
    Milltek uses an HJS cat, which are extremely expensive and are some of the best in the world. Race teams that must run cats because of the rules typically run HJS. Every single WRC team uses them, for instance.
    The cat alone that is in the Milltek B6 HFC is 340 euros (=about $500) if you source it independently. For the extra $300 you get the rest of the pipe and a 2 year, 50,000 mile warranty.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Apr 20 2007
    Lander, Wyoming
    Quote Originally Posted by BARRY View Post
    Varies by state. In PA it is every year. Here they only use the OBD system, there is no actual sniffer anymore.
    Other states are two, three years between emissions inspections.
    Personally, I can't handle the smell of a test pipe. It's like sitting behind a 70's muscle car in traffic. Plus, you are killing the environment.
    Jon
    go > show
    Ich liebe mein Audi
    Buncha motorcycles
    Memphis, TN
    Quote Originally Posted by lookaught View Post
    you can barely smell mine, my cat likes getting high in the garage.
    there are companies like TVA that just spilled ONE BILLION gallons of coal sludge into rivers and over land, thousands of race cars drag and track with no cats, lawnmowers, old cars in states that dont have emissions.....
    i seriously doubt a few thousand cars with test pipes are KILLING the environment
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    It is possible to pass with a quattro and test pipe in CA if you are flashed with REVO.
    For this to happen, you will need to be very lucky...
    1.) The tech has to be able to not notice you have a test pipe with the visual inspection
    2.) Quattro cars do a "no load" test which means they attach a sniffer to the tailpipe and read the emissions, the REVO programming should keep the car running at stoich during the test, then it will be up to the fuel in the car to see to it that is passes.
    IMO it is much easier to have the stock cat reinstalled for like $150 and go get your emissions test, this way you do not have to worry about getting into trouble.
    It is a huge fine in CA for running a test pipe, we are all taking a calculated risk.
    Buncha motorcycles
    Memphis, TN
    i wouldnt do it in a strict state but AR and TN are pretty lax...
    someone made a fake cat test pipe. it looked like a cat but it was actually a test pipe on the inside... not a bad idea IMO
    if you remove it regularly the install/reinstall isnt too bad (its the first time it comes out thats a mofo!).. maybe 1-2 hours once a year
    Dec 25 2004
    Earth
    The state I live in requires annual(yearly) inspection to retain registration/plate....
    Dec 25 2004
    Earth
    The HFC I have, has not caused me a CEL in over 2 years...
    Not all HFC's are created equally
    Dec 06 2007
    my buddies B5 S4 is straight Piped with no cats and passes smog beautifully because his engine is really clean.
    -Kirk
    BetaAlphaTau Member #58
    Dec 25 2004
    Earth
    Quote Originally Posted by Papachristou View Post
    The 2 times I R&R'd mine, both time one/two of the exhaust bolts stripped/galled from the heat/rust. Once one of the studs coming out of the back of the turbo snapped off! The turbo had to be drilled, tapped and a heli-coil installed, while it was in the car...that was it for me!
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    ive never got my car smogged. Its an 03' and I live in CA. Am I in trouble? I have a testpipe btw...
    another stereotypical Audi
    Veteran Member Four Rings got boost.'s Avatar
    Jun 03 2007
    california
    ^^^ i was just trying to order one from VMR but they are sold out. This thread makes me think twice now.
    l BBS l FORGE l STERN l VMR l ER l SPEEDTUNE l
    Jun 03 2007
    california
    i thought $500 was a lot for the Milltek cat. Look here http://www.vividracing.com/catalog/m...5-p-47078.html
    Dec 25 2004
    Earth
    Quote Originally Posted by got boost. View Post
    They have been at that price for a couple years now...
    Strat recently had a %20 off sale, so you could of got'n their MillTek for
    $799
    Nov 02 2007
    SF Bay Area, CA
    Quote Originally Posted by a4wd View Post
    your car will need smog once registration renewal comes up.
    mine is an 02 and it just BARELY was shy of a month when i purchased it before smog was required. I would have had to smog it anyways.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Haaa.... $1 says a4wd needs a smog next year for DMV renewal
    Just did mine this year for the 1st time... 2nd actually since 2003 when I had to cause I purchased from out of state.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Senior Member Three Rings Sp3C14L 3D's Avatar
    Aug 17 2008
    2005 A4 1.8T Ultrasport
    To make this easy for you, just take the testpipe off and put ur cat back on for the smogtest then after you pass, put ur testpipe back on! Theres no way ur gonna pass with out a cat!
    USPCLUB MEMBER#724
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    I just went up to the guy in NV and he did and ODBII scan and I passed. I even told him I thought I might not pass because I didn't have a cat but he said they didn't have to do a visual for that on 4cyl cars. Passed and I'm good for another 2 years.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    May 03 2008
    Orlando
    Quote Originally Posted by Killerteve View Post
    Hey! I got your old pipe installed - love it!
    /resume thread
    Kevin W.
    Buncha motorcycles
    Memphis, TN
    thats one cool inspection guy!
