Results 1 to 12 of 12
    Veteran Member Four Rings jamestown478's Avatar
    Dec 24 2008
    2000 S4 stage 2+ on meth
    Milwaukee
    odd directional problems
    so my directionals have been acting up lately. when I got to use them sometimes they work perfectly fine but then other times the little arrow in the car will blink like normal then start blinking really fast and then shut off. I have no problems with the hazard lights whatsoever and none of my bulbs are burnt out. Any suggestions on what to start looking at? fuses? wiring harnesses?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: odd directional problems
    It's the hazard switch in the dash. Replacement from dealer is around 35 dollars. Did you just get this car recently?
    08 S4- Stock SOLD
    Apr 13 2008
    Tennessee
    2nd on hazard relay
    Dec 24 2008
    Milwaukee
    yea I just recently got this car
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by mholme View Post
    Theres some pretty good info to be had just searching this forum and audiworld. All your basic questions answered. A few stickies as well. Cause if you just got the car..you're gonna have more questions every day Read up, it's all been covered before and you'll save yourself from having to wait for losers like me who are glued to a computer with nothing better to do to reply
    08 S4- Stock SOLD
    Dec 24 2008
    Milwaukee
    does anyone have the part number for the switch by any chance?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by jamestown478 View Post
    http://search.audiworld.com/search.html:
    Enter in search window :"Hazard switch part number"
    Database Filter: S4/RS4 B5 Platform
    Results: 8D0 941 509 H
    08 S4- Stock SOLD
    Active Member Four Rings
    Dec 11 2006
    Boston
    it is a cheap fix...around 44 dollars and takes 2 minutes to swap on your own.
    Stage 3+ RS6's
    Dec 24 2008
    Milwaukee
    ok thanks. That just seems odd how a little hazard light switch could screw with my directionals like that lol
    Senior Member Two Rings Fast Euro's Avatar
    Mar 23 2007
    2005 SLK55 AMG
    Buffalo Grove, IL
    Just be very careful and gentle taking off the hazard surround trim. People often snap it, crack it, or break the clips that hold it in place.
    Dec 24 2008
    Milwaukee
    well I finally ordered the new hazard switch and it came in today. hopefully this solves the problem.
    Dec 24 2008
    Milwaukee
    problem solved :) thanks for the help
