Results 1 to 8 of 8
    Registered Member Two Rings
    Jul 14 2008
    il
    04 S4 Sunshade problem sun shade
    Hey guys,
    in my s4, sometimes when i push the sunshade button it works and the shade moves up and down, and other times, it doesnt...im just really confused and think there may be a problem? sorry if i sound like a beginner but i am
    Veteran Member Four Rings Beelzeebub's Avatar
    Oct 08 2008
    B7 S4
    Re: 04 S4 Sunshade problem sun shade
    did you check to see if anything is getting in the way of the shades going up? I know, it sounds ridiculous, but sometimes, the arms get bent because of people putting stuff back there or it could be a number of reasons. another is the electrical connection. maybe your wires are loose or something.
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    that happened to me once. I started freaking out, but after I parked my car for a while and came back to it, it worked fine. No rhyme or reason why, could be a loose electrical connection somewhere.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    happened to me...only in the real cold weather. i think it sticks to itself. once i heat the cabin up...it works fine. but it happens to me too.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Dec 05 2006
    So. Cal.
    What's the weather like where you are. The shades don't work in the cold weather. it say that in the manual.
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    he is in IL like me....so that would explain it. and yes the button kind of goes dead when its real cold out. when i heat the cabin interior up....it works just fine. but from a cold start...depending on how cold....it won't go up....but i kind of figure that would happen anyway.
    The RIDES:
    AMA Member
    JHMFTW!!
    Jul 14 2008
    il
    ah ok thanks alot...ya it does get cold out, but this did happen a few times in the summer also...i was going to go get it checked out, but thanks alot guys!
    Veteran Member Four Rings mioStile's Avatar
    Sep 25 2006
    Has your car been tinted?
    Possibly could have been affected when they did that. Mine has been very iffy since the beginning as well. S4 quirks.
    Current Iggnshn: 2007 4.2L 6 speed quattro S4. Neuspeed catback. 20x8.5/20x9.5 BBS RSGT. PSS9. USC license plate. always my work in progress.[/FONT]
    AMA
    Together we can all defeat 2.0T and 2.7T crime
    Ya, I'm that guy...
