Results 1 to 14 of 14
    Registered Member Two Rings
    Nov 11 2008
    Roanoke, Va
    Got a check engine light P0420
    Hi my name is Garrett and it's my first post. But I could use a little help I have a check engine light on I've googled it and got back catalyst code. I'm just curious is this most likely an 02 sensor or catalytic converter? Or could it possibly be something else?
    thanks
    sorry its code p0420
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Re: Got a check engine light P0420
    try: http://forums.audiworld.com/vag/msgs/13062.phtml
    but use local search, you may find already answered questions.
    BTW, Welcome to the zine.
    Nov 11 2008
    Roanoke, Va
    Thanks
    Nov 11 2008
    Roanoke, Va
    Where's the best spot to buy vag-com? cable and software. it's pretty expensive on ross-tech.
    Jun 08 2008
    Calgary AB Canada
    ebay.
    got mine for $16. works just fine
    Nov 11 2008
    Roanoke, Va
    Nice. that's what I was waiting to hear. I'm ordering one now.thanks
    Jun 08 2008
    Calgary AB Canada
    make sure it has dual k-lines!
    Nov 11 2008
    Roanoke, Va
    Cool thanks. I really appreciate it.
    Nov 11 2008
    Roanoke, Va
    Would this work? does kkl mean double k lines?
    http://cgi.ebay.com/ebaymotors/USB-C...motiveQ5fTools
    Jun 08 2008
    Calgary AB Canada
    not sure what it means, i just know you need it to work fully with audis.
    that looks identical to the one i bought
    Nov 11 2008
    Roanoke, Va
    Gotcha. I'm gonna order it. It's only $15 bucks and I'm sure it'll work.
    Oct 15 2006
    From a few to one...
    Arlington, VA
    you won't get full functionality w/ an ebay cable. but enough to check and clear codes.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Established Member Two Rings agelosa4's Avatar
    Jul 05 2008
    greece
    b1 s2 lamda sensor..
    audi a4 2.0t quattro- rs4 hofele-dtm rear bumber-ic-76mm exhaust ecu remap etuners-bsr intake-xyz coilover-19s wheels audi r8. rs4 injectors-gt3071 set up 450ps
