Results 1 to 3 of 3
Thread: Bouncing RPMs
    Sep 23 2007
    Bouncing RPMs
    so today i set out to find the leak behind my ecu. So i removed the ecu and then i put it back in started the car and the rpms bounced down to 400 then went to normal idle when i gave it gas. So i disconnected the battery put it back let it sit in the on position for about 20 minutes started it up same thing. I tried this maybe 4 times now and i am getting the same thing everytime. Can anyone tell me what im doing wrong?
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    Re: Bouncing RPMs
    You don't need to make a new thread about this issue, you already have one where people have informed you what to do.
    http://www.audizine.com/forum/showthread.php?t=254386
    Did you do this step at all (that was recommended in your previous thread)
    Quote Originally Posted by Affinitive View Post
    did you do your thottle adaptation???
    Do that and let the car idle and drive it for a bit.
    C
    How to do throttle body adaption:
    put the key and put it into the position just before the starter turns (do not start the car) push the gas peddle all the way wait 3 seconds and turn the key all the way back but do not take it out, now release the gas peddle and wait 2 minutes! remove key than put it back in and start the car
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Sep 23 2007
    Re: Bouncing RPMs
    do i do this before or after i leave it in the on position
