Results 1 to 40 of 44
    Aug 31 2008
    2001 A6 2.7T GIAC flash
    Arizona
    Xenon headlight issues
    Ok, so when I start it up the lights aim perfect, they adjust just a bit to level. Then while driving they slowly drop right down. What do you guys think could be happening? Any and all help is appreciated.
    Veteran Member Three Rings scot_w's Avatar
    Apr 05 2006
    '04 allroad 4.2, '00 A4 1.8T QWSM
    Re: Xenon headlight issues
    Xenons have a leveling mechanism. If they are not aimed correctly, there is a VAG-Com adjustment.
    Aug 31 2008
    Arizona
    I totally understand that, but I haven't changed the aim on them at all anytime recently. I bought a Palm VAg-com, but I can't figure the darn thing out yet. I can't even find the application on the Palm... Ahhgg!!!
    Any other ideas?
    Aug 31 2008
    Arizona
    This hasn't happened to anyone else? Please help!
    Senior Member Three Rings 02alltoad's Avatar
    May 27 2008
    04 S4,Allroad,00 911,00 a6 4.2
    Arvada, Colorado
    its most likely the adjustment motors are they both doing it or just one?
    Aug 31 2008
    Arizona
    It looks like it's just driver's side. I bought these lights about 9 months ago from Shokan too. I know they're good lights, hope it's not the motors. Anyway to check? They still level properly when I start the car up.
    May 27 2008
    Arvada, Colorado
    the way i check it is i park the car facing a wall start the car turn on the head lights and mark on the wall where the beam is and let it run and check to see if the beam is moving down. If thats the case then you need a motor i might have one pm me after you find out
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    I would try to relearn its position with Vagcom. Even though its leveling, it might be an ecu thing. If not its probably the motor. That is an easy fix though if it is. You might want to check the sensor on the suspension and make sure that is cool too.
    EDIT...I just reread your original post. Since it is leveling I don't think its the motors. I would really put my money on it just needs to learn its position again via vagcom.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Forum Moderator Four Rings doobiesdaddy's Avatar
    Sep 05 2008
    2001 Stage 3 allroad 2.7t 6mt TDI gearbox , 2021 Mercedes E 350
    Montana / San Francisco
    any faults show up when you vag-com scan the Xenon's?
    Dave - Moderator
    Issue? send me an email
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down ‘happy’. They told me I didn’t understand the assignment, and I told them they didn’t understand life.
    -John Lennon
    Veteran Member Three Rings RAUDIS6's Avatar
    Oct 09 2006
    Stage 3 B5 S4, LS460, Mini S Countryman
    Check the teeth on the gears of the motors...I had one break on my old A6, and my passenger side one would drop a little.
    Aug 31 2008
    Arizona
    Quote Originally Posted by doobiesdaddy View Post
    Just got the Vag-com in the mail, so I have to figure that part out first. I'm extremely thankful for everyone's help. I will update in a day or so, but please keep the ideas coming!
    Apr 05 2006
    Quote Originally Posted by PMAZ7 View Post
    Xenon Headlamp Adjustment with the VAG-COM
    Aug 31 2008
    Arizona
    Quote Originally Posted by scot_w View Post
    Man, you can't beat this place for helpful Audi folks! I'm going to give it a try as soon as I figure out this Palm deal.
    May 27 2008
    Arvada, Colorado
    Quote Originally Posted by Stampy View Post
    but the motors are not controlled independently so if only one light is dropping its generally that motor but there are always the few odd cases. i would aggree with stampy try to relearn the control position and see if that works first off. oh the lights do a self leveling check every time you start the car thats how they find the control level. Anyway if it does end up that you need a motor ive got 4 extra and ill make you a deal on one.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Let us know whats up. It should really only be one of a few things. Good luck.
    Where did you get the palm Vag, and how much?
    Village Idiot!!!
    (\__/)
    (")_(")
    Aug 31 2008
    Arizona
    Bought it off the classifieds here at AZ. $160 shipped, a good deal?
    May 27 2008
    Arvada, Colorado
    is it shadetree?
    Aug 31 2008
    Arizona
    Quote Originally Posted by 02alltoad View Post
    is it shadetree?
    I don't know what shadetree means, but that wasn't the member's name that sold it to me.
    Veteran Member Three Rings Coors's Avatar
    Aug 21 2008
    04 A4 USP 6MT
    Philly
    Pull the covers off the back of the lamps. Disconnect the wire harness that powers the motors, add some dielectric grease or another non-conductive grease of your choice, reassemble and try that. That worked for me. I also manually turned the motor back and forth by hand. Strictly do not recommend doing this I was just furious at them and figured if I broke them well then I would just get new ones and the problem would be solved.
    Aug 31 2008
    Arizona
    Quote Originally Posted by Coors View Post
    Heading to my shop now to give it a shot. Thanks again, you guys are great.
    Aug 31 2008
    Arizona
    is it shadetree?
    I'm guessing it WAS, but there is NOTHING on the Palm!!! I'm also assuming that shadetree is not a good thing... Hopefully osofast comes through with some support because I could very well be missing something on the Palm.
    Also, the headlight situation is totally intermittent!!! Fell down on the way, worked perfect on the way home... I like those problems the best because they drive me closer and closer to full blown NUTS with each one!
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Do you have a cheap Vag USB cable? You can do the xenon thing with the shareware version of VAG from their website.
    If you were local I would hook you up man. Zona is too far of a drive tonight.
    Village Idiot!!!
    (\__/)
    (")_(")
    May 27 2008
    Arvada, Colorado
    shadetree software is a good program for palm i have a copy of it and i think i paid 200 bucks for it, i know the guy that devoped it. it works just like vag com and the factory 5052b the only thing it cant do is the online stuff there should be an icon on the palm that says shadetree if not you will need to reload the software. and like stampy if only you lived closer i have vag com as well its alot better for reading mvb's and recording logs, anyway back to your palm, ive noticed that if i let my battery go dead the program gets deleted and i have to reload it did the guy you got it from give you the cd and activation code as well? if not i might be able to get it for you idk for sure but ill try.
    Veteran Member Three Rings autophiles's Avatar
    Aug 25 2004
    '04 Discovery SE
    Wilmington, NC
    The same exact thing is happening to my Avant.. they will align every once and a while and then for some reason the drivers side will dip down. Just like your car the problem is intermittent... sometimes it works great.. others it drops. Let me know if you figure out the issue.. I'd love to fix mine too!
    Feb 17 2004
    Sterling, VA
    Like the others said VAG-COM is really important here to run the adpatation process on the motors. You can also recode the leveling setting to see if they move up/down from their first position.
    Here's a chart of the codes for the headlight settings: Click.
    You will need to run the healight adaptation each time you change the settings.
    If that doesn't help, take not is one side is not reponding like the other. At that point you either have: a faulty motor, loose harness or a faulty/loose leveling sensor on the front lower control arm.
    If you can get the part number off one of your motors, I might have a compatible spare I can give you for testing.
    ETKA lists the 2001 to use a 3B0 941 295B.
    2002+ used a 4E0 941 293.
    Let me know.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Aug 31 2008
    Arizona
    That's exactly what I was thinking. It was completely dead when I got it. There are none of the logs that he said would be in the memos icon, NOTHING! And no, he didn't send me the CD, software, or activation code... This is an uphill battle! If you could hook me up, that would be great.
    Aug 31 2008
    Arizona
    Quote Originally Posted by Daft View Post
    Let me know.
    Thanks Daft. Man you guys know a lot! I have a set of headlights that work great but they faded in the Arizona sun, in my garage. I could salvage the motors out of those but I really do appreciate the offer. My biggest issue is going to be figuring out this Vag-com deal. I thought it would have been as easy as buying this Palm deal, but that isn't going so well for me!!!
    Feb 17 2004
    Sterling, VA
    Were you able to get VAG-COM to talk to the cable yet?
    Brett - Moderator
    Issue?: email me.
    Senior Member Three Rings TWINTURBOA6's Avatar
    Nov 20 2005
    Audi A6 2.7T Quattro + more : )
    Rockville,Md
    Quote Originally Posted by autophiles View Post
    YO AMAZING PICS MAN! NICE PORTFOLIO...You got to meet lady dj tribe!? is she sexy in real life? ahaha Again man pics are godly! great job
    Audi D4 Technologist
    Audi Exclusive Service Consultant
    Join us at WWW.QUATTROKINGS.COM for more AUDI excitement!
    Aug 31 2008
    Arizona
    Negative on that. I don't have any access to the application on the Palm. I'm waiting to hear back from osofast so maybe he can help. He's the one that sold me the Palm.
    Aug 31 2008
    Arizona
    Does anyone have the Palm version of Vag-Com with 'prodiag' icon on it? That's what I'm missing. Any tricks to getting it back? I don't have access to the software because I just bought this off someone secondhand. I really need help...
    Aug 21 2008
    09 S60 R-Design, 88 Fiero GT
    Quad Cities
    Thumbs down Re: Xenon headlight issues
    Ugh, I hear ya man. Its hit and miss with this damn thing. Sometimes I can turn the car off and they will re-set, and sometimes it just continues to look like this here:
    This is about 1o-12 feet from the garage door on a level surface.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Quote Originally Posted by mcaanda View Post
    Dude you need to adjust those with the white knobs on the back of the headlights. VagCom sets it to a certain range. The white adjustment knobs let you fine tune them. Looks to me that you are blinding all oncoming traffic with the drivers side.
    Village Idiot!!!
    (\__/)
    (")_(")
    Aug 21 2008
    Quad Cities
    The one on the left is where its supposed to be, the one on the right is the one that will sometimes match the left.
    This was one of the times where it would not go back to where it was supposed to be, so I took a shot of it so that I could show the dealer.
    It's really hit or miss with it but it seems that it's been doing it alot lately more so than not.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    ahh, my bad man. I read it wrong. So you already tried the relearn with Vag and it still does this?
    Village Idiot!!!
    (\__/)
    (")_(")
    Aug 21 2008
    Quad Cities
    Naw, I have not had a chance to get to my buddies place who has the VAG cable. I think that he's got the ( non-OEM ) type that does not have full access?
    To be honest I dont know how / what he's got so its a possibility. If not, Im sure that I can post on NW Quattro and catch the first round to help out for a bit.
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Yeah the ebay cable should do it fine. The free version of Vagcom allows you to do the Xenon adjustment.
    Village Idiot!!!
    (\__/)
    (")_(")
    Aug 31 2008
    Arizona
    As for myself, I'm not having much luck with the person that I bought my Vag-Com off of. So no codes or things to report as of yet... Be wary of purchases like this (although I usually am, and I'm sure you are!).
    Veteran Member Four Rings osofast10's Avatar
    Dec 26 2004
    02 Audi A4 1.8t
    woodbridge, Va
    there is no need to be wary... i told you to talk to ADAM @SPP as he is the one i bought it from... i never got a cd with the palm, so i gave you everything that i got from adam when i bought it on the groupbuy, so talk to him as i have told you over PM please...because when i sold it to you it had all the sofware on it. here is the pic to show you
    last one on the left hand side
    1996 2.8 Audi A4 -> RIP
    2002 1.8T Audi A4 -> SOLD
    2005 Toyota Prius -> DD
    2010 Acura RDX --> DD
    Aug 31 2008
    Arizona
    Quote Originally Posted by osofast10 View Post
    Unfortunately when I took it out of the package it didn't. You might want to keep this in PM mode, for your sake.
