Results 1 to 12 of 12
Thread: Help!
    Sep 23 2007
    Help!
    so i had a leak behind the ecu box, so i removed the ecu to get to it put it all back in let it sit for 5 minutes all the way on the on position. Then i start the car up drive it and when i push the clutch in the rpms bounce below 400 then go to normal what did i forget to do anyone?
    Dec 05 2007
    Re: Help!
    More than 5 min is needed. I usually let the key sit in the starting position for at least 10 min.
    Sep 23 2007
    Re: Help!
    Well im gonna play a round of tiger woods then and let it sit for a while hah
    Sep 23 2007
    Re: Help!
    i just let it sit for a good 20+ minutes and the same thing happened
    Sep 23 2007
    Re: Help!
    anyone?
    Jun 24 2008
    E46 M3
    Woodinville WA
    Re: Help!
    did you do your thottle adaptation???
    Do that and let the car idle and drive it for a bit.
    C
    Sep 23 2007
    Re: Help!
    ok this is pissing me off. Same thing happens everytime, i disconnect the battery, then i put it back let it sit in the on position for at least 20 minutes start it up and every time the rpms bounce down below 400 when i put the clutch in like what is the deal?
    Sep 23 2007
    Re: Help!
    k i did it again disconnected negatibe part of battery put it back let it sit for 5 minutes, then just put it in on position gonna let it sit for another 10 minutes or so is this right?
    Sep 23 2007
    Re: Help!
    alright can like anyone help me because nothing is seeming to work and i dont want to be driving around with a car where my idle bounces down to 400 then settles normal anyone?
    Sep 23 2007
    Re: Help!
    I have tried everything can someone like walk me through it cause obviously im completely missing something
    Dec 05 2007
    Re: Help!
    Try everything step by step. Take your time with it. Make sure the connection on the ECU is good. Remove the negative cable on the battery for 20 min (this is the amount of time I use just to make sure, but 15 min is cool), place the negative cable back on, place key in ingition to starting position with out cranking for 15 min. Should be ok after that.
    Sep 23 2007
    Re: Help!
    thanks man
