Results 1 to 6 of 6
    Dec 28 2008
    Hawaii
    Sharkifin Antenna
    I am looking to possibly put an Audi sharkfin on my VW R32. My reasoning--it seems from looking around the Audi sharkfins can be painted to match. I could do the same with the VW antenna but there is a rubber seal that is non paintable. A local dealer has an 07 RS4 and it seems to be the antenna I am looking for--aka no rubber seal. I need the antenna to have both GPS and Satellite radio aka sirius antennas in the sharkfin. From some reading it seems there is a GPS antenna and a Phone antenna? Is this correct? Does Audi make a sharkfin with a GPS and SAT antenna? I dont need the AM/FM since that is in my rear glass.
    Thank you
    DUH! an Audi
    los angeles, CA
    Re: Sharkifin Antenna
    umm....I thought the audi fin had the gps and sat on it? I would assume it is that way, as radio is on the rear glass as well.
    I would get a vin from a fully loaded s4 on ebay and order that fin, as it would have what you need.
    -randy
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    if you want just the fin, you can buy one that is either black or unpainted on ebay for pretty cheap.
    Dec 28 2008
    Hawaii
    i want the fin and antennas. So an S4 has the GPS/Sat antenna in the car? Thanks
    Veteran Member Three Rings 04Ultrasprt's Avatar
    Jan 13 2008
    North NJ
    The S4 antenna should, as should any 2004 and newer A4 sharkfin. From 2004 on, Audi prewired A4's for Sat Radio and Nav. You just have to make sure that there are 2 fakra style outputs.
    Previous rides:
    Lotus Elise - B6 S4 Cab - E90 335i - E46 ///M3 - B6 PES Stage 2 S4
    B6 Nogaro S4 - B5 S4 Stage II - B7 A4 2.0T K04 - B6 A4 1.8T USP
    USP CLUB MEMBER #95
    Dec 28 2008
    Hawaii
    thanks alot-I am going to be looking for a 07 ^ antenna as it is not as big and Bulky. Thanks again.
