    Registered Member One Ring ogreb5's Avatar
    Aug 10 2008
    winnipeg
    2001 a4 1.8t car does not start
    it cranks but does not start
    its keep cranking but nothing happen
    need help guys
    thanks
    Aug 04 2007
    92 Jetta,2001 A4 2.8
    Cranston, RI/MA
    Re: 2001 a4 1.8t car does not start
    is fuel getting to the engine??
    ~Bo
    92 Jetta- daily-slammed,TP...to much to list
    01 2.8- project
    Aug 10 2008
    winnipeg
    didnt check that yet
    its too cold here
    ill check that
    thanks
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Did you do anything to the car prior to it not starting?
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    ya id say crank it for a while. get a small screwdriver, take the cap off the back of the fuel rail and press the pintle. some fuel should spray out. if not, first check fuse 28 (fuel pump). if thats ok, and you have no fuel in the rail, most likely a pump.
    if you do have fuel pressure, try unplugging the maf as a HUGE vacuum leak will cause it to not run, but it should at least start for a second.
    does the engine sound like it is freewheeling? no start could also be a broken/stripped timing belt, but that usually goes while you are driving. hope this helps. peace.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
