Results 1 to 6 of 6
Thread: Which wire?
    Veteran Member Four Rings AudiXS4X01's Avatar
    Nov 11 2006
    01 Audi S4-Santorin Blue
    Tri-State
    Which wire?
    Hey guys, the shop that installed my Avic-D3 didn't tap into the wire for my "night mode" I searched, but couldn't find the answer to this..
    "Night mode: when you flip on your headlights you can choose how dim you want the screen to get, and the navigation screen has a night mode which uses darker colors for the map, and is much easier on the eyes to be activated."
    Anyone know exactly which wire needs to be tapped into? Pics would be great, otherwise a description should suffice.
    Dan
    Veteran Member Four Rings Big Boost's Avatar
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Re: Which wire?
    Can you go into the system settings and just turn on Day mode full time? I know you can in the Z2 and Z3.
    2015 Audi A3 Stage 3+
    2001.5 Audi S4 VRT
    Nov 11 2006
    Tri-State
    Re: Which wire?
    thats the problem, i have day mode on all the time..i can hardly use the nav at night cause its soo blinding. I want it to be able to switch into night mode at night.
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Re: Which wire?
    What kind of aftermarket harness was installed? Find the illumination wire on the harness to tap into.
    2001.5 Audi S4 VRT
    Nov 11 2006
    Tri-State
    Re: Which wire?
    right, but where do i tap into the car after I know which wire?
    Jan 28 2008
    S4VRT
    Milwaukee, WI
    Re: Which wire?
    Tell me the brand of harness you have so I can look up the diagram to tell you.
    2001.5 Audi S4 VRT
