Results 1 to 11 of 11
    Oct 30 2006
    B8 A4 Avant 6spd
    Misfires (Non Typical)
    I figure I'll post in here seeing that my 01 has an 06A motor like B6's, while most B5'ers are 058.
    This is going back on these threads. Please read prior.
    http://www.audizine.com/forum/showthread.php?t=252684
    And
    http://forums.vwvortex.com/zerothread?id=4167082
    Anyway just to go over what I have replaced.
    4 new coil packs
    Maf
    Front 02
    Running virtually new F5DPOR Sidefires (They are pregapped) (Also tried BKRE6s and BKRE7's gapped at .028)
    Replaced all rubber vacumm hosing, this baby is as tight as a whistle no boost leaks.
    Both Stock and Chipped Ecu have the same issues.
    Thinking about:
    Intake temperature sensor - Though bad IAT sensors causes serious cylinder retardation, and I'm not getting any crazy timing pulled.
    Map sensor - Though symptoms aren't consistent with a bad map
    I have the evap simplification mod, all evap BS removed.
    Suggestions?
    -18 718 GTS
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    Re: Misfires (Non Typical)
    If you have access to a five gas machine you can see what is going on and tell weather its mechanical or a ignition issue.
    That will really break it down for you. Where are the misfires taking place... low, high, idle? sorry i havnt read your other post
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by Audi Skate Snow View Post
    They're generally under load. But on cold start-up when idle is held @ 1200rpm it misfires at that point as well for a good 5mins straight, sounds like a machine gun. (Exhaust is fairly loud haha) Once it warms up it happens when spooling for boost, they MOSTLY happen between 2000-3000rpm but they do happen in the upper rev band as well, just not as much.
    -18 718 GTS
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    Are you pulling any codes?:
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Oct 30 2006
    B8 A4 Avant 6spd
    Quote Originally Posted by A4 Moda View Post
    On occasion it'll pull a multiple misfire code. But not as often as you think, the misfires are bad to the point where the CEL flashes.
    I have a evap incorrect flow code (but that's from the evap system removed, and I had this misfire issue before I removed it.)
    -18 718 GTS
    Oct 30 2006
    B8 A4 Avant 6spd
    Replaced the fuel filter, though it was pretty clogged, it wasn't the problem causing the misfires. =/
    -18 718 GTS
    Mar 31 2004
    CA
    you try your fuel pump?
    Oct 30 2006
    B8 A4 Avant 6spd
    Its not the fuel pump, has to be an injector issue, or compression issue.
    I don't care anymore, the car is being stripped down for a BAT build today. I'll be replacing the fuel pump and injectors regardless.
    -18 718 GTS
    Mar 31 2004
    CA
    Quote Originally Posted by Militant-Grunt View Post
    hahah... yea shit is a nightmare. I didnt get a chance to read the other threads, but misfires can be a million things.
    try getting a hold of a noid light to test the harness on the injectors itself.
    good luck brotha!
    p.s whats in plan for the BAT build?
    Oct 30 2006
    B8 A4 Avant 6spd
    good luck brotha!
    Stayed tuned in the B5 builds and project section is all I can say for now =).
    -18 718 GTS
    Jun 11 2005
    are you running a program that uses the MAF?
    Multiple cylinder misfires can be attributed to a failing maf.
    It would suck to go through all the trouble of a BAT then to uncover that it does the exact same thing.
    My bet is MAF.
    GL
    2003 1.8T
