Results 1 to 8 of 8
    Dec 28 2008
    New York
    Car Trouble, Need Help
    Multiple codes came up when I scanned my car Audi A4 03 1.8T:
    P0300 - Random/Multiple Misifire
    P0301 - Misfire Cyl 1
    P0302 - Misfire Cyl 2
    P0303 - Misfire Cyl 3
    P0304 - Misfire Cyl 4
    First tried to Resolve the Misfiring, replaced all coils and plugs , but misfiring still occurred. Took it to Audi and they told me it was due to faulty wiring to ignition coils. Wiring was replaced and misfiring stopped for a couple days, but today random misfires began to occur again and check engine light turn on and was flashing. Any suggestions on what else it can be?
    Also other codes came up:
    P1297 - Connection Charger Throttle Valve Pressure Drop
    P0238 - Turbocharger Boost Sensor Circ. High
    P0106 - Map Circ Range Performance
    What can I do to fix these problems?
    random car problems occurring:
    When car is in Park or Neutral the tachometer is constantly revving between 1500 - 2500 rpm, but drops down to normal under 1000 when it is put in Drive or Reverse. What can cause this?
    Also, information display signaled having low oil, but when checked it was regular. Then when I screened it again everything came up OK. This had occurred twice. What can cause this?
    Any feedback and help would be highly appreciated.
    Veteran Member Four Rings A4 KiDD 810's Avatar
    Aug 25 2007
    B6 S4
    Westchester, New York
    Re: Car Trouble, Need Help
    wow that stinks . What part of ny u from?
    -Nick
    -2004 Brilliant Red S4 6Spd - Thermal R&D Catback, FK Coils, Piggie pipes, JHM Tune
    -2002 Brilliant Black 1.8T 5Spd - (traded in) Gone but never forgotten
    Jun 08 2008
    Calgary AB Canada
    vacuum leak for sure. had very similar problems along with the idle issue.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    +1 on a possible vacuum leak. open your hood and try to listen to any unusual "sir sucking" sounds :)
    Senior Member Three Rings rocketheavy's Avatar
    Mar 21 2008
    A4, Explorer, YZ250
    Connecticut
    you have a serious vacuum leak. I got the same codes when I didnt put the valve cover breather tube on all the way after I replaced the rear coolant flange. It miss fired like a mo fo. Put the tube back on, reset the codes and now it runs like a dream.
    03' 1.8T Tiptronic
    Baileys DV, 15% tints
    Ziza yellow Fogs
    Blacked out grills/trim, De Badged
    Apikol snub mount, clear corner mod
    A6 engine mounts
    Dec 28 2008
    New York
    thanks for the advice.... How would I go along finding the leak?
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    post # 4 also try to see if any of the check valves are cracked
    or the best way is to do vacuum leak test
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Quote Originally Posted by AudiNYA4 View Post
    Make one of these:
    http://www.a4mods.com/index.php?page...tml&category=5
    And check the suction valve and hoses that are closest to the firewall - this is near the coolant reservoir:
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
