Results 1 to 26 of 26
    Oct 20 2008
    B7 A4 2.0
    Jax Fl
    Little weekend ipod project
    decided to do this DIY this weekend. i recently got a dice kit and am using that. i chose to have it off center to have the easiest access to all the ac buttons and to the ipod so the shifter wont get in the way. it looks very rough right now because its only the epoxy and no bondo yet.
    Oct 20 2008
    B7 A4 2.0
    Jax Fl
    Re: Little weekend ipod project
    progress
    Nov 12 2007
    Grand Junction, CO
    You could've just bought one from 3point5.com.....although probably more expensive..
    Here is mine..
    Oct 20 2008
    B7 A4 2.0
    Jax Fl
    ya, i spent about 20 in supplies, $150 is out of the question
    Oct 20 2008
    B7 A4 2.0
    Jax Fl
    almost done
    Nov 12 2007
    Grand Junction, CO
    Looks great!
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    only problem i see is not creating a large enough passage for different types of iPods in case you decide to upgrade/downgrade in the future or wanted to hook up a friend's iPod/iTouch, etc.
    overall for DIYers and your ideas
    Junior Member Two Rings
    Oct 31 2008
    06 A4 Quattro 2.0t 6spd
    Abbotsford BC CANADA
    Quote Originally Posted by AudiWxGuy View Post
    Here is mine..
    Where on that site can you get it? Also I see you have the iphone. are you using dice???? Will it let you listen to the Tuner application "IE: live streaming radio over 3g?"?
    thanks
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    nice work
    i have the Avic D3 so my pod just sits in the glove box
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Nov 12 2007
    Grand Junction, CO
    Quote Originally Posted by polonez View Post
    thanks
    www.3point5.com
    I forget what module I have. I know I can listen to Pandora over Edge...
    DUH! an Audi
    los angeles, CA
    pretty good ipod connection, love people doing the DIY, nice seeing the progress.
    I have to agree, that it should have been just the adapter, not everyone has a mini, so if you wanted to hook up a different ipod it prob wouldnt work. But, like most people, you only really use yours and no one else ipod.
    -randy
    Senior Member Three Rings rams456's Avatar
    Jan 05 2008
    Audi A4
    Bay Area
    how do you operate your climate controls?
    2008 Audi A4 6 Speed Manual, Quattro, Titanium Package, S-Line, Debadged, Boost Gauge, RS4 Sway Bar, Front Plate Delete, Stasis Exhaust, JHM "Extra" Short Shift Kit, Stasis K04, 034 HFC
    Nov 12 2007
    Grand Junction, CO
    You reach behind the iphone...or god for bid I have to take it out for 10 seconds...:-)
    I will admit it is a little tricky.
    Veteran Member Four Rings CZA420tAvant's Avatar
    May 24 2008
    06 A4 Avant 6MTQ Brilliant Red
    Orange County, NY
    Which dice adapter did you use?
    Looks great.
    Driving: 2006 Brilliant Red A4 Avant 2.0TQM
    Revo Stage 2|Carbonio Intake|Stasis SS coils|Podi Gauge|iForged 19"|H&R spacers|RS4 F/R sways|custom inlet pipe|Milltek turbo back with custom twin tips
    Endorsing:
    Oct 20 2008
    B7 A4 2.0
    Jax Fl
    im using dice, so if i ever get a new ipod i will just have to do the project over. it was not hard at all, took me 1 day from start to finish. the dice kit also has a normal headphone output, so if i get a male-male headphone cord then i am pretty sure i can listen to anyone elses mp3 player.
    tada
    Veteran Member Four Rings SLYCAT's Avatar
    Sep 26 2007
    Augusta
    Dude you got some skillz, nice work.
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    looks good! I love my DICE/PRO CLIP setup though (off to the right side)
    Nov 12 2007
    Grand Junction, CO
    Looks great!
    Veteran Member Three Rings Spiff69's Avatar
    Nov 22 2008
    2021 Ultra Blue SQ5
    Quote Originally Posted by nsmith12 View Post
    Pic?
    Nice job OP!
    May 24 2008
    Orange County, NY
    [QUOTE=BlowDro;3200410]im using dice, so if i ever get a new ipod i will just have to do the project over. it was not hard at all, took me 1 day from start to finish. the dice kit also has a normal headphone output, so if i get a male-male headphone cord then i am pretty sure i can listen to anyone elses mp3 player.
    which dice kit did you use and where did you get it from, was it easy to hook up wth no issue?
    thanks
    Endorsing:
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    Quote Originally Posted by Spiff69 View Post
    Pic?
    Nice job OP!
    Nov 22 2008
    2021 Ultra Blue SQ5
    ^^^ Nice, thanks - Does that not keep your glovebox from opening properly? Looks good - did you have to secure it on both sides?
    OP - did you feed the ipod cable behind the HVAC controls, I'm assuming?
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    nsmith, how is your wire routed? I have mine going straight to the glove box. Yours might be a better option than mine:
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
    Nov 01 2007
    B7 A4 2.0TQT
    PA
    BTW I don't want to take credit for this, I bought exactly what JMG had bought just wired it differently. The wire doesn't get in the way of the glovebox opening nor does the cradle, the great thing is that you don't have to drill a hole. I just slipped the wire in between the glove box and the center console, very stealth.
    Awaiting Confirmation Four Rings
    Feb 29 2008
    2006 A4 2.0T Quattro, Dolphin
    San Francisco Bay Area
    Yep, +1 to this; there is enough of a gap between back area of the center console and the edge of the glove-box - I have a hard-wired portable Sirius player mounted in exactly the same place and have 3 wires all doing that, too - one for power, one for audio, and one for the sat. antenna. My office's network hates Photobook for some reason, so I'll post a pic of this when I get home. It does, however, look almost identical to the last pic in nsmith's post.
    Great work, OP, looks clean!!
    Oct 20 2008
    B7 A4 2.0
    Jax Fl
    i ordered it directly from dice on black friday. the instal was pretty simple. all you need to do is plug in their harness. i also had to solder on an extension for the ground wire because it was to short.
