Results 1 to 14 of 14
Thread: CEL and codes
    Veteran Member Four Rings jamestown478's Avatar
    Dec 24 2008
    2000 S4 stage 2+ on meth
    Milwaukee
    CEL and codes
    so my check engine light randomly came on today. I scanned it and got the following codes. P0300 which comes up as: the PCm has determined that multiple random misfires have occured. and P1606 which shows as unknown to autozones computer system.
    Does anyone know what would be the cause of these codes and what the second code even is?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: CEL and codes
    The misfires could be anything from bad plugs/coil pack to a boost.
    The second one- A quick search on audiworld shows this:
    18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
    P1606 - 35-10 - - - Intermittent
    Following posts suggest that it could be a failing ABS module, I don't have any personal experience though..
    That's about all the info I have.
    08 S4- Stock SOLD
    Dec 24 2008
    Milwaukee
    Re: CEL and codes
    how often do the coils go bad? and while changing my spark plugs I accidently severed the connection on the sensor connected to the coolant container in the engine bay. how bad is that and what are my options to fix it?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: CEL and codes
    Quote Originally Posted by jamestown478 View Post
    Coil packs fail when they fail, if your car is higher mileage, it's possible that one could be bad. What are the specs on your car and what plugs are you using?
    For the sensor, just splice it back on, wrap it up with electrical tape or solder the connection and heat shrink.
    08 S4- Stock SOLD
    Dec 24 2008
    Milwaukee
    Re: CEL and codes
    car has 95k miles using ngk plugs
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: CEL and codes
    Which NGK plugs? Are you stock, chipped?
    08 S4- Stock SOLD
    Dec 24 2008
    Milwaukee
    Re: CEL and codes
    I am stock. I have iridium ix plugs I believe plugs. I got whatever they ordered me at autozone for my car
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: CEL and codes
    If this just started happening(the misfires) as you changed the plugs recently, I would suspect them. Check the gap and that the coil packs are seated well. Try to get a hold of an actual VAG-COM in your area to help with diagnosing this and your other problem accurately.
    08 S4- Stock SOLD
    Dec 24 2008
    Milwaukee
    Re: CEL and codes
    I just replaced the plugs. I bought them last night and got the cel today
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: CEL and codes
    I'd say that's probably your issue then. Put the old ones back in and if you don't get misfires...there ya go..
    08 S4- Stock SOLD
    Dec 24 2008
    Milwaukee
    Re: CEL and codes
    I meant that I bought the plugs last night, but didn't install them until today after I got the cel. does the light go away on its own once the problem is fixed or do I have to have it reset?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: CEL and codes
    Multiple misfires are a flashing CEL. If the light is still on, it may be from your other code. You really need a VAG if you are going to diagnose the issue. Otherwise, you're just throwing money at the car. Aren't the plugs like 8 dollars a pop too?
    08 S4- Stock SOLD
    Dec 24 2008
    Milwaukee
    Re: CEL and codes
    haha yea there expensive. but I was told that u should change them every 100k and im at 95k so I figured why not replace them a little early. I think I might run it down to international autos tomorrow and see what they say about it.
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: CEL and codes
    Buy cheap copper spark plugs, change them every oil change. Also, invest in the VAG-COM for these cars, plus a pressure tester. They are must haves if you want to save yourself time and money.
    08 S4- Stock SOLD
