Results 1 to 19 of 19
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Dual projector carbon fiber headlight update
    Usual disclaimers that ths project is not done, and all of the imperfections you can see are known and will be gone as more resin layers are applied and sanded.
    Turn signal trim:
    This trim is complete and is matte finished. The rest are all still gloss because I haven't sanded level yet. You can really tell the difference when holding the matte trim next to the stuff that's still gloss.
    Here is one for the DIY, lol. Second headlight housing just after overlay applied.
    Here is one just to see how lens trims look in rough pre-sand stages. They aren't clicked in place as I have to trim CF on the main housing first.
    Still a little tack to them so I'll leave them for the day and start in to first sand-downs tomorrow.
    And another without second projector mounted in place:
    Turning out good so far for an overlay, especially. Not too much sanding needs done.
    Should have both done by end of week. Then I need to do test-runs on the LED's to make sure I don't have heat issues. Then I hope to have functioning auto-dimming S5-look LED's in addition to the dual projector housing.
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    Re: Dual projector carbon fiber headlight update
    Wow that looks really cool, can't wait to see the finished product. keep us posted
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Dec 06 2007
    i am 100% impressed good work Lee
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Three Rings ehfour's Avatar
    Feb 19 2005
    2002 A4 1.8T
    Vancouver
    Amazing work!
    How hard is CF to work with?
    Similar to Fiberglass?
    Veteran Member Four Rings UnkleGatsby's Avatar
    Jan 09 2008
    S8
    Ketchum Idaho
    I have always wondered about this. Looks like its coming along swell. I am excited to see the finished product.
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by ehfour View Post
    Amazing work!
    Thanks. Very similar, except you really have to worry about how the flow of the weave lines looks. Keeping weave straight in places where it should be straight is tough. Just takes patience. But other than that, it's different from how I normally lay fiberglass in that I usually saturate the fiberglass weave first, whereas on CF, I apply resin to the surface of the part to be covered, wait for it to become very tacky (using a heat gun helps make this faster), and then gently push the cloth in to the tacky resin. Start in the middle and work out. I use various tools to push the cloth in to the right angles and nooks. If I didn't wait long enough on that resin, the cloth won't stick well in tight curves or right angles. If I have a trouble spot, I use a heat gun to dry resin until the clotch holds. Once the initial overlay resin is dry, I then start slapping on top coats of resin. I usually start sanding high spots by about the second top coat. I keep re-applying and sanding out after that until surface is smooth. Then fine sand and spray with matte clear.
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    i hope your taking pictures for my site woman!
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    FWIW, carbon fiber is used extensively in many hobbies (rockets, RC cars, rc airplanes, Rc boats) and there are tons of videos on YouTube that show the processes.
    I really like what you made, personally though, I would have roughed it in fiberglass and bondo and then did a vacuum bag overlay.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Great work but I've never been a fan of CF.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    thats awsome i am a carbon fiber whore i need to learn how to do this
    Mar 21 2006
    Lakeland, FL.
    To me it looks like black fiberglass.
    I'm back bitches!
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Feb 28 2006
    Pittsburgh-Philly
    Vacuum bagging is useful when multiples are made, or when you have made a mold and want the final product to be just carbon fiber.
    Since mine is purely aesthetic in nature, I opted for the overlay. I need all the inside plastic to hold the projector housings in correctly. It has to be sanded smooth, which makes many extra steps over vacuum bagging, but I wasn't about to buy all I'd need to vacuum bag for one project.
    Longer process, but it's actually cool seeing it take shape from my own elbow grease. Sand, layer, sand, layer, buff.
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by martini View Post
    What are the things in the first post beeyatch?
    I'm taking pics as I can, but unfortunately none during some working processes. Can't stop what I'm doing to take a pic. Especially when resin, epoxy, or fuzor is involved.
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    get someone to stand over your shoulder!!
    Quote Originally Posted by rxrep View Post
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    Seriously though, CF the part of my headlihgts that normaly gets blacked out in Joey mods. I have no faith in my own skilss to do this. Can I bribe you with Euro parts?
    -Tim
    Feb 28 2006
    Pittsburgh-Philly
    Quote Originally Posted by sandspeed View Post
    I think CF overlay is no harder than painting them. Shit can get 'spensive though.
    If I wasn't balls deep in my own projects I'd consider it. I'm already consumed.
    Veteran Member Four Rings jon102034050's Avatar
    Oct 02 2006
    MN
    jeez, every time I see your work I just get jealous, these are going to look so sick when your finally done
    A4 1.8TQ - RS4 Sway - Avic-D1 - Neuspeed Sports - Bilstein Sports - Joey Mod
    Veteran Member Three Rings whiteUSPflow's Avatar
    Feb 22 2008
    2004 USP 1.8tQ, 2003 RS6
    Richmond, VA
    bad ass man i would pay really good money for a set of thows. i thought about doing it myself but i was going to just do the inside trim plastic piece. but wow they look amazing good job!
    USP CLUB MEMBER #97
    APR tuned K04-Carbonio-Forge-Podi-Stasis-034 Motorsport-RAI motorsport
    Unitronic tuned RS6
