Results 1 to 4 of 4
    Senior Member Two Rings collegedude10's Avatar
    Jan 06 2008
    A5 3.2 6MT, B6 A4 3.0
    electrical gremlins...
    so i dont know whats going with my car. nothing really just i keep getting random lights on the dashboard. the low oil light was coming on even though i had oil, so i changed the sensor. that seemed to fix that problem for a while.
    Then yesterday out of nowhere the air bag light comes on, then flashes, then stays steady, then goes away. and when it goes away then the low oil light comes back on. all the while the headlight bulb light comes on even though i have them on and they both work.
    i was wondering, are these messages controlled by the ecu? would investing in a new ecu perhaps fix this?
    2009 Audi A5 3.2 6MT
    hopefully this list grows...
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    Re: electrical gremlins...
    i dont know about the ecu but i would disconnect the battery for 10-15 min, this is supposed the rest the ecu,
    just make sure you have the radio code before you do it
    Please Drive Right
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    You compouter might have thrown some codes. VAG the car and find out
    -Sami-
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    my oil light came on one day when my coolant was low and my car started to overheat...its weird i would try the what sami said wag the car and see
