I'm working on my turbo manifold today and just realized that I hadn't put any consideration into the routing of the screamer pipe. I have a nice merge into the 10 deg. collector but need a plan as for where to dump the wastegate discharge. The only open dump WG I've had was on a balls to the wall DSM, and it had a tendency to behave like a flamethrower. is that what I should expect out of my B5?
The setup is tial/Garrett full V-band GT3076R on an equl length tubular header and into 3" straight exhaust, low-z 750cc inj., A1000 Fuel Pump AN lines throughout, fully forged bottom end, meth injection, direct port multi stage nitrous, Megasquirt II v3.0 EMS running batch fire fuel and sequential fire COP ignition. -I intend to run 25+psi...
SO... as for the wastegate dump... any suggestions on where to route the discharge pipe so as to avoid flambe' -ing things?
