Results 1 to 40 of 40
    Aug 04 2007
    92 Jetta,2001 A4 2.8
    Cranston, RI/MA
    Kinda Stuck on a project of mine
    Well i got a bunch of money from x-mas and decided to start saving for an engine swap..out with the boring 2.8 and in with well not to sure yet cant decide between the S4 2.7TT or the VR6 24v which is a 3.2L(correct?)
    Ive done research but i cant seem to find the pro's and con's of each engine...my project will aim for 650-700 ft/lbs of torque hp..what ever comes about mainly looking for torque
    sorry for the newbie question i just unsure of the pro's and con's...yes i did a search but i am horrible at searches on the zine
    ~Bo
    92 Jetta- daily-slammed,TP...to much to list
    01 2.8- project
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    Re: Kinda Stuck on a project of mine
    The 3.2 VR6 is out of an R32 if I remember right. The GTI VR6 is a 2.8. However both are mounted laterally so special mounting is going to be needed. However I would do a VR6.
    The sound and power band are awesome in it. Obviously a 2.7TT will be stronger stock I would imagine anyways and have more options but the VR6 has many options available to it. All in what you want. If I had the time, money and talent to do a VR6 swap I would in a heart beat.
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    I would keep things simple a go with a supercharger kit or just find a S4.
    Taking things to the next level and building something cool and thus expensive a VR6 would be fun and sound awesome. That would be a ton of work. Your money, your call. Take a look at 034 Motorsports time attack car for some inspiration. That car is fast...
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Aug 10 2008
    sehg
    Thumbs up Re: Kinda Stuck on a project of mine
    Quote Originally Posted by D's Avant View Post
    My exact thoughts on this as well, though my intentions are not to discourage you from whatever it is you plan on doing with the car. The VR6 has more potential over the 30v 2.8 that's in our b5s, since you can go either way with them and the 30v in ours isn't really built for modding though you can drop a supercharger into it and gain a substantial amount of horsepower. If you're looking to save money and get the most that you can, I'd suggest a GIAC Chip, Supercharger, Full Catback exhaust if you haven't already, and a cold air intake as starters..goodluck with again whatever it is you decide to do!
    Aug 04 2007
    Cranston, RI/MA
    So far the vote is for a VR6 Swap, I have plans to weld up my own 3" down pipes to a 2.25" exhaust or something there about, but at the same time im not sure i wanna spend that money if im going to get rid of the engine anyways. I have realized that the engine needs new mounts and that 034 sells all the pieces necessary to swap in a VR6
    just saw the video of the 034 motorsport time attack and to quote Jeremy Clarkson, " I want that in my life"
    ~Bo
    01 2.8- project
    Veteran Member Three Rings black00A4's Avatar
    Oct 19 2006
    Ontario, Canada
    Just rebuild your 2.8 and then supercharge it.
    2000 Audi A4 2.8L Quattro Sport - Volcano Black
    Mods: 18" A8 Rep's, Ebay SS & Strut tower bar, PureMS Snub mount, K&N, MAF de-screened, H&R sports, STERN power ring & diff mounts, Cupra Lip, DEPO ecodes, Unitronic flashed ECU, Magnaflow
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    To hit that power level expect to spend at least $10,000....
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
    Aug 04 2007
    Cranston, RI/MA
    i realize to hit that power level im gonna have to drop some serrious cash
    ~Bo
    01 2.8- project
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    i think you should go that route : )
    *creamed myself when i looked at those pics again*
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    has anyone been able to do the VR6 swap besides 034?
    __________________
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    What kind of power curve do you want? Do you want a lot of low end power or do you want a bunch of power up top with little down in the low rpms?
    My vote would be to basically replicate the 034 time attack car and go with a 24v VR6, build it to rev high, throw an HTA35r or comparably sized Bullseye turbo on it, use the 034 IIc ecu to have a race gas file and pump file.. you'll need to figure out a transmission that can handle the power and a serious clutch....
    That would be a MONSTER car.
    because racecar.
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    the 24v vr6 is a 3.2l transverse mounted v6. it was available in the r32, as well as the 3.2l mk1 tt q dsg, and i believe also the limited production VW beetle RSi.
    my vote would be to swap a 12v vr6 as it is a much more common and thus, available powerplant. the money you save going 12v vs 24v can be applied to a BAT setup (vr6t). this is the engine used in the 034 time attack car. talk to issam. since they have already done it, they can help shed light on various issues with the swap (mounts, fueling and ignition system, tach, etc). im not sure if the 24v head bolts up to the 12v but i assume that it doesnt. either way the vr6 is definetly up for the challenge.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Aug 04 2007
    Cranston, RI/MA
    Quote Originally Posted by Kyle H View Post
    I am aiming for more low end power rather than high end power
    Flynnr..i need to change my pants now wow!
    ~Bo
    01 2.8- project
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Borden View Post
    650bhp can be made on an almost stock 2.7T bottom end, that's not power at the wheels though, that's at the crank. Look into the Tial R650 or comparable packages if you want to go that route.
    However, being a firm believer that the 2.7T is less than ideal for building as a powerhouse, I'd recommend the 2.8L VR6. You can put the R32 24V head on and there's plenty of turbo manifolds, tuning, and parts backing.
    As far as I know, or have heard, after 034 built their Time Attack car there was a limited production of the parts needed to swap the engine into the B5 chassis. I believe 5 "kits" were made, and it included the custom starter, mounts, etc. To the best of my knowledge all 5 were sold, but I'm sure somebody may know differently, or would be more credible.
    I don't want to start the argument over the 3.2L bottom end or the 2.8L bottom end, but if it was my decision to make, the 2.8L bottom end would be my starting point.
    2.9-2.9L is all you will ever need to make the power you desire, both reliably and a very usable power curve.
    Unfortunately I don't believe there's a twin scroll manifold available for the VR6/B5 chassis swap. If there was I would go that route. I'm a believer in twin scroll more and more everyday.
    If you're looking to build 650-700HP at the wheels, you would need ~850 at the crank. You're looking at a BullsEye S300 series, Precision PT72, Garrett GT4xxx, etc turbos.
    Depending on what you have available for fabrication and what you can do yourself, you're looking at probably $3K just to get the engine mounted, starter, trans mounts, subframe madifications, etc. $4K in a turbo, manifold, downpipe and oil/coolant lines, $5K+ engine - built head(cams, lifters, valves, springs, porting, etc), fully balanced internals (aftermarket rods, pistons, and probably a stock crank modified). That wouldn't include your clutch, flywheel, axles, fittings, lines, coolers, oil filter relocation, downpipe back exhaust, upgraded brakes so slow that thing down, high volume electric fans + controller, Standalone engine management + tuning, gauges, air intake setup, or gaskets.
    I'm sure I forgot something in there.
    Good luck, keep us posted.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    If you're looking for low end power in the 650-700HP/TQ range you're not going to get it out of a 6cyl unless it's coupled with a supercharger properly sized for your goals. And to be honest I don't think you can hit 600bhp easily on a supercharged 6cyl and maintain low end power.
    Here's my suggestion.
    LSx Adapter plate to 01E transmission
    You get that guy to make another adapter plate and I'll build you a 600+HP LSx to bolt up to it.
    Problem #1 you're still not going to have a ton of low end power without shelling out the big dollars for big cubic inches.
    What power numbers do you want at what RPM?
    Senior Member Two Rings mainer0311's Avatar
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    Quote Originally Posted by le91688 View Post
    A good friend of mine swapped a vr into his audi 90. He has it running and driving with an hx35 bolted to the exhaust manifold. He used 034's tranny adapter and starter, most of the rest he built himself, the motor mounts and all. With the 90 you don't have cut the rad support like you do in the a4's.
    Cooper
    Aug 04 2007
    Cranston, RI/MA
    Quote Originally Posted by djwimbo View Post
    Im looking for the tq band to start at around 3000rpm(to possibly 4000 but that is pretty high in my book) it can carry up to w/e it needs if that's not feasible then ill work with what ever is
    ~Bo
    01 2.8- project
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    for the displacement the VW/Audi community has to offer, full torque at 3000rpm and as much as you want isn't going to happen very easily.
    4000rpm on a VR6-T is where the numbers start to really take off.
    You have to remember, if you gear ratios are well set up, you only see the spectrum of 3000-4000rpm once. Shifting a A4 5sp, S4 6sp, or most other transmissions, you will stay above 4300rpm if you're shifting at 6500rpm. A built VR6-T will spin higher than that, which will pull the RPM up higher after the shift.
    Apr 06 2008
    Brandon, FL
    ive said it before n ill say it again: "vr6t ftmfw"
    Current whip:
    RIP:
    Aug 04 2007
    Cranston, RI/MA
    I can live with that my next question is what transmission to use? should i keep my 2.8 tranny? or should i get a S4 tranny and hardware and swap that in as well i do love a 6 speed
    ~Bo
    01 2.8- project
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Since you already have a V6, the S4 trans mounts up to the same ones you already have. You should upgrade the mounts to something like the "density line" from 034MS, but the actual dimensions and style are identical. The difference is in the subframe between the S4/V6-A4 and the 4cyl A4.
    6sp > 5sp.
    Aug 04 2007
    Cranston, RI/MA
    Thanks for all your help guys and clearing up some problems, exp djwimbo.
    for clarification i should get a
    12v VR6/and mounting hardware
    BAT
    S4 tranny+ new mounts
    Fueling
    Bigger Breaks
    making the tach work and any other misc things
    ~Bo
    01 2.8- project
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    2.8 Supercharged is where its at.
    __________________
    Veteran Member Three Rings mikevets68's Avatar
    Mar 30 2008
    Retired. 2007 Brilliant Black Audi A3
    Irvine
    Quote Originally Posted by flynnr View Post
    Holy sh**T that Turbo makes my little OEM turbo look like a dust particle! lol
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    BAT
    Fueling
    Bigger Breaks
    The 12V VR6 will be the cheapest option and can actually make some pretty damn good numbers on the stock bottom end. You can pick 'em up at almost any junk yard or VW parts recyclers.
    The 24V head or the R32 24V head would just allow for more flow and more power.
    But basically, yes, you're on the right track. Just don't forget about all the "little" things, like a clutch, hardware, fittings, etc.
    I will mention that the 034MS VR-T A4 is using a stock A4 man trans radiator and it's working just fine.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    The 24v VR6 head flows way more than the 12v. It is so good stock that it isn't worth the expense to port and polish it on a street engine.
    2.0 or 3.0 would be great but 2.8 liters is also fine. Because of the larger displacement you can run a larger exhaust a/r which will help make more top end power too. A twin scroll will help make the powerband wider which gives you the best of both worlds.
    There are a variety of VR6 turbo manifolds available but I don't know which would fit the A4 engine bay.
    I've owned a VR6 and loved it. I would rather have a 172hp naturally aspirated VR6 in my Avant than the 240hp K04 1.8t that is in it now. I've also experienced VR6 turbo power and it is verrrrry nice indeed.
    Jim
    I Do Werk.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    I will be swapping a VR5 or VR6 into my A4 in the next year. I'm also located near you, you should swing by my shop and check out some of the cool B5 motor swap/builds I have going on
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by 317ssayzarc View Post
    and send me pictures. b/c I'm jealous
    Aug 04 2007
    Cranston, RI/MA
    Heck yea man that would be sweet i feel like my pocket book is gonna hurt but it will be sooo worth it in the end
    where are you guys located and ill stop by some time
    ~Bo
    01 2.8- project
    Mar 09 2004
    nw michigan.
    I'll send you an extra DO WERK license plate in return for some royalty checks.....
    Jim
    I Do Werk.
    Oct 27 2007
    In the lab
    Send me a pm with your number, I work strange hours (when I want lol)... I'll arrange a nice lil tour
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    First visit is a tour then you need to do work in that shop :)
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Nebone View Post
    I'll work at his shop, but I don't want to move to RI.
    Oct 27 2007
    In the lab
    You guys crack me up...
    Much love guys
    Senior Member Three Rings erode's Avatar
    Nov 07 2008
    05.5 B7 S4, 98 E36 M3, 03 E46 330xi
    MN
    A noob looking for 700hp or lb-ft of torque and still hasn't decided on an engine!
    Very ambitious. I assume you are simply throwing wads of benjamins at this project and it's not a homebrew.
    Oct 06 2004
    Minnesota
    Lets see a 2.7T with dual 35R's
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Four Rings anmagro's Avatar
    Sep 14 2008
    I love reading about these VR6 swap threads because they give me great incentive to keep my 2.8 in hopes of either going through with the supercharger or actually doing the swap. with 113,000 on my clock and the next 4 years of college to keep the car, its nice to know i can put cash into the other aspects of the A4 knowing a better power plant is possible. I have the mod bug in a 2.8 30V with plenty of time on my hands! ha! I think the VR6 would be a great powerplant for what you are doing. One of my friends has a 12v VR6 and the thing hauls azz. Not sure what turbo, but hes pushin 400whp on the thing. What are some prices for a good used Vr6 these days anyway? My friend grabed his from an old lady partin out her car for dirt cheap.. lol
    Black On Black 98' Audi A4 2.8L 30V 5spd. Quattro "Esabell"
    BBS RK's - Zimmerman - Vogtland Sports - Thrush Welded Cat-Back - DDM 6000 - Reigar RS4 - K&N Spectre - EbaySS - SpeedTuning Stage I
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Quote Originally Posted by A4Rob View Post
    talk about never spooling...
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Oct 27 2007
    In the lab
    At your request Rob
    http://www.motorgeek.com/phpBB2/viewtopic.php?t=20624
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    ohhh boy u have no idea what goes on into swapp
    GIAC-X, STASIS TS,VAST,034 MS
