Results 1 to 15 of 15
    Senior Member Two Rings supersweet's Avatar
    Dec 16 2008
    Santa cruz, Ca
    Rear Speakers Behind Rear Seats
    any special speaker that it must be replaced with it, any suggestions?
    Sep 03 2007
    Wichita, KS
    Re: Rear Speakers Behind Rear Seats
    Don't replace them. I just did with some Infinity components and I had to disconnect my sub and feel the speakers to see if they even worked. They just don't produce much sound compared to the rest of the speakers in the car. If they are rattling, search for the DIY to reglue the dust caps.
    Aug 06 2008
    Canadia
    Quote Originally Posted by jerodmetcalf View Post
    use the "hidden" equilizer to crank up the rear volume, or just set the fader more to the rear.
    the B5 S4 is like the mafia... there is only one way out!
    Veteran Member Three Rings NOVAS4's Avatar
    Sep 02 2007
    2003 Audi RS6
    Woodbridge, Virginia
    what exact infinity's did you use?
    Current: 2003 Audi RS6
    Current: 2008 Acura RDX Tech (daily driver)
    Previous: 2013 Hyundai Genesis Coupe 3.8, 2006 Acura TSX, 2008.5 Mazdaspeed3, 2000 S4 Sedan 6sp stage3-, 2004 Subraru WRX
    Aug 11 2008
    sehg
    the rear speakers on my b5 a4 2.8 quattro were crackling a lot when i first bought the car back in may, and was told the same that everyone else is mentioning. since the rear speakers have a built in amplifier and overpower the front speakers, fading the speakers out won't produce the best sound if that's what you're concerned about. i ended up replacing the speakers there and all around in my car as a whole for competition speakers. now the car sounds amazing and don't regret the purchases any bit. I went with Kicker Speakers for my doors and behind the back seat, and quantum tweaters.
    Active Member Two Rings cgm246's Avatar
    Nov 10 2008
    08 B7 Brill. Black 2.0T CVT
    Fort Lauderdale, Florida
    is there a hidden eq in the symphony II system, if it is, i could not access it as mentioned for the bose system.
    08 Audi A4
    Senior Member Two Rings sti4now's Avatar
    Oct 21 2008
    Turbo M3
    NC
    get kicker compVT drop in subs.....plug and play no need for an amp
    ECS stage 3 S4, APR stg 3 fueling, APR K04 turbo kit, Iforged Aero 19" wheels, Reiger front bumper, ABT sides, Samco TBB, JHM FMIC, H&R coilovers, Porsche stage 4 cayenne BB kit, AWE DTS, RS4 Clutch, SS kit, FORGE DV's, JE design Heckspoiler, ECS shiftknob w. suede boot, VDO boost gauge
    01 Stage 3 S4, AWE turbos/fueling, H&R race springs, O.Z Superleggaro's, JHM FMIC, JHM solid SSK, SSAC TBE, Samco TBB, VAST stage 3 clutch, VDO boost gauge.
    Sep 03 2007
    Wichita, KS
    Quote Originally Posted by NOVAS4 View Post
    They are the 6010cs speakers without the tweeters or crossovers. I bought them dirt cheap from a guy that couldn't pay his rent.
    I have adjusted on the hidden eq and faded them and still don't get much sound out of them. Maybe that is because I have a 1000 W amp on a 12 in the trunk and it overpowers those in comparison.
    Oct 31 2005
    Ashburn
    There was a previous thread about this, someone was saying you have to match the speakers that your replacing in ohms, and I believe i heard the fronts and rears are 2ohm speakers. If i find the thread i'll paste it in here.
    Also for those that don't know how to access the EQ, turn radio off, hold down the 5 button(or the 5th preset button) and turn the radio back while still holding it. And then a EQ with a numbers will appear with all 5's, you can you the the Volume to change the value and P-scan to move to the next number. Once your done press the power buttonto turn the radio off and then turn it back on and the settings should be effective.
    - Instagram: @Sinister_rs5-
    Established Member Two Rings jay340S4's Avatar
    Oct 03 2008
    2000 Audi S4, 2009 Dodge Ram 5500, 2002 Toyota Highlander
    Prince George, BC, Canada
    where does a guy find stock bose speakers for our car
    Oct 31 2005
    Ashburn
    Quote Originally Posted by jay340S4 View Post
    classifieds or Ebay
    Senior Member Two Rings Aphex350's Avatar
    Feb 11 2008
    Peekskill, NY
    Quote Originally Posted by sti4now View Post
    x2
    2000 Santorin S4
    AWE Stage 3+
    Senior Member Three Rings Boosted-S4's Avatar
    Aug 03 2008
    Silver S4
    dont replace them..they are top quality speakers that produce way better sound than most aftermarket junk out there!!!
    Sep 02 2007
    2003 Audi RS6
    so theres no need to get any wires or any adjustments to anything.. just plugs right in?
    Sep 02 2007
    2003 Audi RS6
    also its 4ohm .. i guess that doesnt matter?
