Results 1 to 7 of 7
    Active Member One Ring mkell's Avatar
    Aug 23 2005
    STL
    How to find options?
    I am looking at a '07 with the titanium package and am wondering if there is a way to find out what factory options the car has? I'm not too familiar with what was available when these cars were new and the seller isn't sure.
    Nov 12 2007
    Grand Junction, CO
    Re: How to find options?
    Probably via the VIN
    Aug 23 2005
    STL
    But what would I do with the vin? Would a dealer be able to find that info for me from the vin?
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    Yes. The dealer can use the VIN to find all of that info. You could probably use google too, but I can't remember what info I was able to find with mine. You could also search google to see what options were available that year. If you have the Tit then you will also have the S-line and Premium I believe. If you have a big screen in the console then you have the nav. If you have little dials that go to six then you at least have the heated seats, but may not have the cold weather package. If you have the knobs in the back then you should have the cold weather package. You should ask about the bluetooth, satellite radio, and the flux capacitor (it let's you go back in time). You could also have the sunshades. I am not sure what else was an option that year, but that should be most of it. You will not have tilting mirrors for when you back up or memory seats. For some reason neither of those were an option that year. It really sucks and some day I will get that memory seat.
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
    Aug 23 2005
    STL
    Thank you very much for the help!
    Veteran Member Four Rings EMAXX's Avatar
    Jul 12 2008
    If you also have the factory sticker, you can just look on there and the it will list all of the options and the standard features.
    2015 Audi S4 Prem+ Sepang Blue/Magma, 6MT, Eurocode Alu Kreuz, Eurocode Transmission Brace, Eurocode Sway Bars and Endlinks, RocEuro Intake, AWE Touring Exhaust
    Feb 23 2008
    Use both the VIN and the option codes, but that may not tell you everything.
    I ordered my A4 3.2l 6sp 4-dr quattro (order code 8EC5P9) with these order code options:
    2Y2Y Ocean Blue Pearl paint
    NK Ebony Interior
    6W3 Front License Plate Holder (required here)
    7X1 Parktronic
    N0K Premium Leather Seats
    PAW Cold Weather Package
    PBS Audio Package
    PPX Convenience Package and
    PQE Titanium Package
    Buried in these order code options is the S-Line package, Satellite Radio, iPod interface, Bluetooth, in-dash 6-disc CD changer, power glass sunroof with slide and tilt, tire pressure monitoring system, Homelink, Bi-Xenons, etc...
    My VIN doesn't translate to those options using the URL below, neither do the Option Codes, so without actually knowing what to look for, and what the Convenience package included for a given year, getting this info may be challenging.
    Translate your VIN here: http://www.motoverse.com/tools/vinDecoder.asp
    Mine shows this (but it's wrong - I have the 6 speed manual trans):
    2008 AUDI A4 S 3.2 QUATTRO AWD
    World region: Europe
    Manufactured in: Germany
    Year: 2008
    Make: Audi
    Model: A4 S 3.2 QUATTRO AWD
    Body style: Sedan 4 Door
    Transmission: 6 Spd Automatic
    Drive type: AWD
    Fuel type: Gas
    Cylinders: 6 Cylinders
    Safety restraints: Dual Front, Head and Side Air Bags
    Standard options: Air Conditioning, Power Steering, Power Brakes, Power Windows, Tilt Wheel, Sun Roof, ABS (4-Wheel)
    Then, in the spare tire well in the trunk, there is a sticker (mine is in the corner nearest the right taillight) that has a good number of 3-character codes printed on it, each of these codes specifies one option that your car had installed at the factory.
    There is a thread about these codes (and a download link for the spreadsheet) out on audi-forums: http://www.audi-forums.com/b5-forum/...odes-here.html
    My `08 A4/B7 has this set of options listed on that sticker:
    trans: M6S
    eng code: BKH
    paint: LZ5C/LZ5C NOK/NK
    E4J 7A6 4UB 6XL 5SG 5RW
    1KW J0R 1LA 1BE
    3FE 5TL 7X1 4R4
    F0A 8GR 0G1 0YK 0JJ
    T14 3NZ 8EH U1B X9A 1N3
    2PU 8Q5 9Q2 8Z6 D2G
    7Q0 CJ6 7K7 4X3 2K8
    3L4 4KC 3Y0 4K8 5D2
    1SA 7GA O1A 4GP
    The Audi Option Code spreadsheet translates that to the following:
    E4J S-Line
    7A6 Cd Player And Cd Changer
    4UB Airbag For Nar
    6XL Outer Rear View Mirrors: Powered, Heatedelectrically Foldable, Automatically Dimming, With Memory Function
    5SG Outer Left Rear View Mirror: Flat
    5RW Outer Right Rear View Mirror: Convex, Uslarge Viewing Field
    1KW Disc Brakes, Rear
    J0R Battery 380 A (80 Ah)
    1LA Disc Brakes, Front
    1BE Sports Suspension/Shock Absorption
    3FE Electric Slide/Tilt Sunroof With Sun Screen/Sunblind
    5TL Decorative Inserts In Piano Lacquer
    7X1 Ultrasonic Park Distance Control
    4R4 Power Windows With Comfort Operation Andcircuit Breaker
    F0A No Special Purpose Vehicle, Standard Equipment
    8GR Alternator 150A
    0G1 Gearshift Lever
    0YK Weight Category Rear Axle Weight Range 10
    0JJ Weight Category Front Axle Weight Range 9
    T14 Components For Base Engine, Unit 06E.A
    3NZ Rear Seat Bench Unsplit, Backrest Split Folding
    8EH Bi-Functional Headlight With Gas Discharge Lamp, For Driving On The Right(Us Design)
    U1B Instrument Insert With Mph Speedometer, Clock, Tachometer And Trip Odometer
    X9A National Sales Program Usa
    1N3 Speed-Related Variable Steering Assist (Servotronic)
    2PU Steering Wheel Sport For Airbag System
    8Q5 Headlight-Range Adjustment, Automatic- Dynamic With Cornering Light (Afs 1)
    9Q2 Multi-Function Indicator/On-Board Computer With Check Control
    8Z6 Engine Cooling System, Type 2
    D2G 6-Cyl. Gasoline Eng. 3.2 L/184 Kw 24V Fuel-Stratified Injection Base Engine Is T14
    7Q0 Without Navigation Device
    CJ6 Alloy Wheels 8J X 18
    7K7 Tire Pressure Control, Frequency 433 Mhz basic Level Version
    4X3 Side Airbag Front With Curtain Airbag
    2K8 Reinforced Bumpers
    3L4 Electric Seat Adjustment For Both Front Seats, Driver'S Seat With Memory System
    4KC Side And Rear Windows Tinted
    3Y0 Without Roll-Up Sun Screen
    4K8 Radio Remote Controlled Central Locking Operated From Inside, Front And Rear And Separate Trunk Release
    5D2 Carrier Frequency 315 Mhz
    1SA Without Additional Engine Guard
    7GA Emissions Concept Lev 2
    4GP Windshield Tinted With Sun Band And Viewing Window For Vehicle Identification Number
    Hope this helps, best of luck
    2008 A4 B7 3.2 Quattro 6MT, S-Line, Titanium, Ocean Blue Pearl, Prem BOSE, Cold, Conv, Volterra Leather, BT, iPod
    2008 A6 Avant 3.2 Quattro 6AT, S-Line, Night Blue Pearl, Prem, Nav, Milano Leather, Cold, iPod
    2010 S5 Prem+ 6MT, Brilliant Red, Black/Platinum, B&O, Nav, Sport Rear Diff, Mods...
