Hey guys, well the other day when it was cold out i was fixing some things and well in the process i happen to break something. However i have no clue what it is. It runs into that blue bubble(refer to picture). I think it might be something for my EGT? It is some kind of vacuum.
Also i pulled the plugs today, they look a little lean? What do you think(had a misfire and my engine just has not seemed right lately. Maybe because it just hit 70 grand on Christmas.
BTW: as you can see in the pictures i had to make a new tube(runs across the engine where can i get a replacement for that so i don't have that big ugly yellow silicone tube.
Pictures: its the little broken tube---
blue bubble--sits below the drivers side light at the bottom you can see it clearly when you take off the belly pan
Plugs---
Plugs do look lean to me, but just seeing for your opinion, Also flash was on so everything does look a little iffy.
