Results 1 to 19 of 19
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    Front to Rear ratio
    does anybody know the quattro front to rear wheel power ratio on an 05 A4 1.8TQM? thanks
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    Re: Front to Rear ratio
    Pretty sure it's 40 front / 60 rear. 99% sure.
    Edit: 99% sure, 100% wrong.
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    Veteran Member Three Rings A4_Mike's Avatar
    Apr 09 2007
    2014%20Audi%20A4%2C%202017%20Audi%20Q5
    Cary%2C%20NC
    I thought the new B8 platform is using a 40/60 F/R ratio whereas the B5/B6/B7 platforms use a 50/50 F/R ratio?
    Confirmed via wikipedia - 50:50 (F:R).
    2014 Audi A4 2.0T quattro | Volcano Red | Chestnut Brown | Tip | P+ | Nav + | Sport | B&O
    2017 Audi Q5 2.0T quattro | Ibis White | Ebony | Tip | P
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    There is no true ratio...bias is based upon the specific load that the torsen sees.
    Oct 15 2006
    From a few to one...
    Arlington, VA
    in general 50:50. when need be, up to 66% of power can be transferred to whichever side has more traction.
    '97 A4 1.8TQ, '02 A4 1.8TQ Avant, '03 A4 1.8TQMS, '04 A4 3.0Q Cabrio - Sold
    '18 S4 Prestige - Kohlefaser Luft-Technik Intake
    Senior Member Three Rings vc1492a's Avatar
    May 04 2008
    Knoxville, TN
    Quote Originally Posted by A4_Mike View Post
    X2
    2010 A4 2.0T S-Line Cab (CVT)
    2004 Stage 2 Mini Cooper S
    Sold: OEM+ 2005 Audi A4 USP 1.8T
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    Quote Originally Posted by NyteEscape View Post
    x2. torque bias is constantly changing. acceleration: up to 66.6% rear, deceleration: up to 66.6% front, constant speed ~50/50
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by 400HPA4 View Post
    Veteran Member Three Rings ThatGuyAlex's Avatar
    Jan 24 2008
    NorCal BayArea
    Quote Originally Posted by Exanimas View Post
    If that was the split you could drift the car in the wet super good. But its not.
    Thank god you did not put your life on that!
    Fastest slow car down mountain roads you ever saw!
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    Like 400HPA4 says.. it is based on the load that the torsen (center diff ) sees. Its not 50/50 or 60/40 it is constantly changing
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Is it true the R8 is something like 70/30?
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    Quote Originally Posted by Charlescrs6 View Post
    i heard 80/20, but its something like that because it can do tight doughnuts all day on dry pavement
    Please Drive Right
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Pothole View Post
    yea, my friends STI can rip doughnuts all day with 80/20
    - Clint
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Donuts are no big deal...they are pretty hard on the steering rack though.
    Aug 10 2008
    Denver, Colorado
    Quote Originally Posted by downhillracer View Post
    but it is limited by the center differential's built in biasing ratio. no more than 2/3 of the engine's torque can be transmitted to either end of the car. torque bias is based on load and traction. when you accelerate weight transfers to the rear, the rear has more traction and load capability, so up to 2/3 of the engines torque goes there. opposite is true when you decelerate; front has more traction and load on it, so more deceleration torque is transferred to the front(not really noticed).
    a lot more goes into road holding characteristics (doughnuts) than torque bias (power, suspension, tires, weight distribution, etc.)
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    The only thing you need for donuts is more power than traction...
    This was done on dry pavement with a stock bias center diff. http://www.youtube.com/watch?v=_gIGFY7KgO0
    Jun 02 2008
    mmmmmmmmmmm i do like doughnuts
    Please Drive Right
    Established Member Two Rings Plasticar's Avatar
    Jul 08 2008
    B6 A4Avant, B5.5 Passat 4mot
    West Bloomfield, MI
    Yes, it self-adjusts to provide power to the best axle, that is what the torsen center dif does. It means TORque SENsing. The default ratio, however, IS 50/50 for all A4/5/6/8 cars up to the most recent redesigns B8/C6.5/D3.5 I believe are the designations. The R8 is probably different, and the TT and A3 uses the Haldex system based on FWD, so it is mostly or all FWD in normal and sends some to the back as needed.
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by Alex@GMS View Post
    My post was edited for clarity.
    -Nick
