Results 1 to 26 of 26
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    Need to buy following items
    1) Engine Mount
    2) Tranny Mount
    3) Rotors all around
    4) Pads all around
    want a nice smooth ride - nothing aggressive - just a DD
    Post up some nice prices / sites
    Gracias
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Abt AS400 clone, 13 Allroad/RS5 swap
    SoCal, but not the nice part
    Re: Need to buy following items
    You want us to go shopping for you? I charge for that.
    -Tim
    Veteran Member Four Rings Stone825's Avatar
    Dec 02 2008
    nowhere
    Audi A6 2.7T : 6MT : 88K Miles : GIAC Chip : 2.5" Catback : Hotchkis F+R Sways : AWE DTS
    Dec 18 2006
    Hanover, NH
    Rs4 mounts are stiff no? whats a good replacement mount
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Dec 18 2006
    Hanover, NH
    yeah was looking at those
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by 47Ronin View Post
    Well look no further - 034 is the pit stop for engine tranny mounts. The rest is up to u basically. Folks might be put a little on the spot without a spending limit for ur items. After all it is "ur shopping", have u tried the website sponsor ECS Tuning to get a "FEEL" for the prices. There are dozens of brake options out there. Everyone here can recommend something different... that wouldn't help. From ur description I would say B7S4 front brake upgrade for a smooth everyday driver with ur future turbo upgrade.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Veteran Member Four Rings audi til I die's Avatar
    Mar 04 2008
    IL
    034 mounts
    Stoptech BBK. Either way you'll need a brake upgrade for the BT set up.
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    get mounts form 034, rotors from ecs, and hawk hps pads w/sensors from tire rack. you should be good to go.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    two thousand two audi a-four quattro five speed
    Dec 18 2006
    Hanover, NH
    Okay will get 034 mounts ... who's the 034 rep on here?
    Also I'm not doing "upgrades" my stock ones are messed up - i think maybe warped and just want to slightly upgrade perhaps
    im not going BT on this car anymore (should probably cchange my sig) but i'm in HK for a year - 2 years and when I get back i'm buying another a4 or an a5
    So all I need are some drilled / slotted rotors and pads that will be as good or slightly better than the a4 - nothing too crazy like bbk
    Dec 18 2006
    Hanover, NH
    I see on ECS' site
    ECS - ECS Slotted Rotor - 11.3" (288x25)-Pair, Zinc Plated ES#11
    ECS - ECS Slotted/Cross-Drilled Rotor - 11.3 (288x25) - Pair, Zinc Plated ES#12
    Zimmermann - Plain Rotor - 11.3" (288x25)-Pair ES#10
    Is just changnig front rotors enough or shoudl I get rears too?
    and which one of those is better / does it make a difference?
    Dec 18 2006
    Hanover, NH
    Also
    what is difference between
    Tranny Mount, Density Line, B6 Audi A4 1.8t
    Tranny Mount, Motorsport, B6/B7 Audi A4 4-Cylinder
    Tranny/Diff Mounts, Audi, Motorsport Spec
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    Quote Originally Posted by diztek View Post
    done!
    Dec 18 2006
    Hanover, NH
    Okay
    1) Mounts from 034 - but which one? I don't kknow which tranny mount ... they have liek 3 different ones
    2) Rotors
    I can't decide between ECS, Adam @ SPP's rotors or Brembo Slotted Sport from Tirerack ....
    what do you guys think? Is brembo really worth teh extra $60 for front + rear?
    Dec 18 2006
    Hanover, NH
    Also for the rear rotors how do i know if i have 245 or 255mm without removign the rotors? ...
    May 13 2008
    NoCal - EBay
    Also
    Actually the 2 main different 034 engine/tranny mounts I know of are:
    1) Street Density - Quite a bit stronger than stock and are not fluid filled better for a stock feel with virtually no engine vibration
    2) Track Density - Stronger than Street Density. Noticeable engine vibration.
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Dec 18 2006
    Hanover, NH
    right i knew that too but look at the tthree they list .. the pictures are different too
    May 13 2008
    NoCal - EBay
    I would say call them up and ask to speak to Dan but I believe they are on Christmas Break. If they look that different are they for our car? or for a completely different one. They are only human after all they had the B5 snub listed for the B6 for a while. It wasn't till I walked into their shop that they produced the Apikol... so... who knows??? The only real choice is the one I posted earlier::: Street/Track Dan should know about any "new" stuff they have.
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Buncha motorcycles
    Memphis, TN
    PM issam@034. i got street density engine mounts and track density tranny. i am very happy with the combo
    APR Stage 2/AWE Intake
    Dec 18 2006
    Hanover, NH
    Alright - Rotors ordered
    Now decidi ng between PBRs and Hawks - what do you recommend for street driving?
    May 13 2008
    NoCal - EBay
    Hawk HPS is low dust and work great on the street.
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    034 is out of street density mounts and as far as I know, they do not have a solid date when they will be back in stock.
    I have not heard anyone complain about the quality of their mounts. You should be able to get the tranny mount right now
    I run the RS4 mounts and after one track event they sucked just as bad as the stock mounts.
    Dec 18 2006
    Hanover, NH
    o so they dun have engine mounts? pooop
    what mounts do they have then
    May 13 2008
    NoCal - EBay
    Quote Originally Posted by 400HPA4 View Post
    I have the street density tranny mount but others say the track density works fine with no discernable roughness.
    >>> ATTENTION >>>
    This is in regards to "tranny mount" only
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    034 has track density engine mounts in stock, (they do not have the street density engine mounts) however you will most likely feel noticable vibration, especially at idle.
    They are a performance part, so there is a slight trade off to sacrifice performance over comfort.
    The vibration is nowhere near as bad as a misfire, but you will feel it slightly in your hands on the steering wheel, on the shift knob, and if you have a soda can in the dash cup holder, you may here a slight buzz through it.
    Once the car is moving, there is no difference whatsoever.
