Results 1 to 8 of 8
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    A lot of B5 S4's
    WA
    Bad rattling from front end
    So just the other day sometimes at idle I noticed the car making this horrible rattling noise. Its coming from what seems to be right around or below the fan, sounds like a bad pulley or something of some kind. Here's a video of it, any ideas?? And it never matters if the cars hot or cold.
    http://www.youtube.com/watch?v=YBy9waa1OuQ
    Registered Member Three Rings kovalevandrew's Avatar
    Oct 19 2008
    South Africa
    Re: Bad rattling from front end
    You weren't kidding when you said bad. Holy shit. Sounds like the noise i have on my aircon pump pulley, but yours is 5 times louder.
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    alternator would be my best guess, if not power steering pump. Are you having any electrical issues? I seen this happen on an 06 cherokee where the bearing in the alternator went and it had that grinding noise like that. would get louder if you accelerate and then the voltages and lights for the dash/radio would be all over the place.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Veteran Member Four Rings A4 Effort's Avatar
    May 28 2007
    '99 A4 2.8 / '07 A4 S-Line Avant / '09 A4 S-Line 2.0
    Mt. Airy, MD
    Sounds like your belt tensioner pulley
    | 2007 Ibis Ti S-Line Avant | APR Stage 2+ | APR HPFP | 034 HFC | Forge DV | Stasis Exhaust | KW V1 Coilovers | SPC Adjustable Control Arms | 19" MRR GF6s | 034 TIP | 034 Sway Bar & End-Links | K&N Drop-In | Deval CF Front Splitter | Relak CF Sideskirts | S4 Recaros | TT-Sline MFSW | P3 Vent Gauge | RS4 Grille | RS4 Fog Grille Mod | RS4 Pedals | RS6 Shift Knob | OEM+
    Feb 15 2007
    marimont
    Could be your injectors. bc how mike pointed out your inj are open 100% all the time.
    Oct 26 2006
    A lot of B5 S4's
    WA
    How might it be injector related? I don't hear any kind of sound coming from near the fuel rail or anything. The sound does look like its coming from close to the PS pump, but I haven't had any power steering issues. Also I don't believe its the alternator because I run a sub and amp and have never had any charging issues.
    Oct 26 2006
    A lot of B5 S4's
    WA
    Also off idle the sound basically disappears and I thought tensioner at first too, but the sound seems to be coming from a different area...
    Registered Member Two Rings
    Jul 24 2008
    Los Angeles, CA
    I am pretty sure it is your timing belt cover. It's the black plastic piece held on by two clips in the front of your engine right b/w you and the plastic 5V Turbo engine cover. I had the same noise when I put clipped it back on after I changed my valve cover gasket. Just wiggle the cover up (the clips will still hold it into place) and the belt will no longer rub up against it and stop making those noises. It scared the crap out of me when I first heard it too.
