Results 1 to 17 of 17
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Removing glove box lock cylinder and components.
    Any body have any idea out to thoroughly remove the glove box lock cylinder and perhaps detach the glove box LID from the rest of the housing?
    (I cannot seem to pull the pins out of the hinge)
    Thanks
    -Sami-
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Removing glove box lock cylinder and components.
    Audi > A4, S4 > 2002-2007
    Body Interior
    68 - Storage Compartments and Covers
    Glove Compartment Lock Handle, with Knee Bolster, Removing and Installing
    Removing
    Open glove compartment cover.
    Remove bolt - 1 - of handle - 3 - on left side of glove compartment.
    Pull handle - 2 - off from glove compartment cover.
    Installing
    Installation is reverse of removal.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Audi > A4, S4 (B6, B7) > 2002-2008
    Body Interior
    68 - Removal and Installation.Glove Compartment Cover
    Removing
    Remove glove compartment.
    Press pin - 1 - out in - direction of arrow - at connection between brake for glove compartment cover - 2 - and glove compartment cover - 3 - .
    There are holes on the inside of the glove compartment at the left and right by the hinge.
    Knock the pins - 2 - on left and right out of the glove compartment - 1 - using a drift (4 mm).
    If there is no hole, proceed as follows:
    Pull pin - 2 - inward on left and right inward and remove using a pliers.
    Remove glove compartment cover.
    Installing
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Pics would work better then red x's.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Bentley probably does not like hyperlinking...he can get a three day sub for $20
    Veteran Member Four Rings martini's Avatar
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    its super easy.. just open the glove box and take out the one screw on the drivers side of the glove box... the whole assembly comes out
    a4mods.com Stickers!
    http://www.a4mods.com <-- Thats my website!
    - My vehicle is stock.... I promise -
    - BetaAlphaTau member #4 -
    Feb 19 2007
    Charleston, SC
    Quote Originally Posted by martini View Post
    I took that screw out and tugged like hell on the latch and got nothing.
    Its not like it was about to come out or something....it felt and looked like that screw made no difference whatsoever
    -Sami-
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    I had mine out the other day... let me think, im not in front o my car so i wont be able to tell...
    let me mull it over
    Feb 19 2007
    Charleston, SC
    let me mull it over
    The only thing that would make sense, is for the whole black vover (the one behind the actual door) to be pulled off. But it seams like it is physically attatched to the door and will rip if I try to take it off.
    -Sami-
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    i definetly didnt take the black back panel of the box off.. .its seriously just that screw then you unlock/open the handle and it should come out
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    High speed Ferrari movement...
    Feb 19 2007
    Charleston, SC
    /\ That has nothing to do with my problem
    -Sami-
    Jul 27 2008
    Miami, FL
    Whoops I thought u ment the cylinder on the side.
    Aug 10 2004
    2002 A4, 1.8TQM
    www.a4mods.com
    random.. dont know if you ever got this... but i just took mine off again
    you literally just remove the one small torx screw on the inside edge of the drivers side of the glove box
    then to remove the handle, dont pull on the handle as if you are opening the glovebox door... instead just take a small flathead screwdrive and pry the handle on the edge where the lock is located... it pops right off
    if you yank from the physical handle (like you were opening the glove box), it iwll not come off
    Jul 14 2009
    Pasadena
    any one have a part number for a new handle?
    Widebody 19 Audi SQ5 ABT|HRE|034|WAGNER - GONE
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Jun 19 2012
    Kent, UK
    Hi, there. I am realy new to this but I have been trying following the directions above. I know it's an old thread but it helped to a point. I am afraid to break my handle. Did anyone have any success on this. Like absolutegtr I have had no success.
    Anyone?
    Jun 19 2012
    Kent, UK
    Hey there, don't worry. I did some bashing and got it out, now to solve the other matter.
