Results 1 to 4 of 4
    Veteran Member Three Rings bmags88's Avatar
    May 12 2008
    B6 1.8T A4 / 06 Lincoln Navigator(Ultimate)
    Massachusetts/S Shore
    Figured out my cooling fan issue...finally!
    After weeks of forum searching and messaging my fellow AZ'rs I've figured out why my fans keep kicking on while sitting in the driveway/garage.
    I took off my ECU cover to find this under the ECU.
    The Problem. Submerged relay.
    The cullprit. Cracked ECU cover.
    The cost of a new relay and ECU cover..$70 from Audi
    - Mags
    2003 1.8T A4 Quattro
    18" B5 RS4 Gunmetal Reps / K&N Drop-in / Helix Ecode Reps / Forge DV / DTH side skirts / 6000K Lows / OEM S6 LED DRLs / CF Beltline Trim / Blacked-out upper/lower grills / Parrot MKi9200 / Podi (Stewart Warner) Gauge
    USP Lower Front / S4 Grill
    Veteran Member Four Rings aLeXliu911's Avatar
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    Re: Figured out my cooling fan issue...finally!
    i had that issue too this summer.
    my water temp went up to 120 degrees when i was on the track.
    then after 2 month, the water temp stays at 60 all the time, coz the fan was on all the time. then i scan my car and get short ground code, clear it, everything is normal. then i realized that why my water temp went up to 120 when i was on the track, the fan never went on.
    BetaAlphaTau member #11
    2003 A4 1.8T 5SpdMQ Black
    545awhp, 477.4awtq
    Stasis Motorsport C/O
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Status Carbon Fiber Seats. ER Comp FMIC
    2008cc, AWM, Ported AEB Head, HTA GT3582R,Full Race Exhaust Manifold, INE Intake Manifold
    Sep 14 2006
    2003 A4 1.8T QM
    Vancouver
    i will check my ECU box too. coz i have radar jammer wire go thru the box.
    thx for the hint.
    545awhp, 477.4awtq
    Stasis Center Diff
    Stasis Rear LSD
    Stasis Alcon BBK
    Saint Cloud, Fl
    good find, thats kinda scary actually
    instagram ------------> low_enforcement
