Results 1 to 10 of 10
    Registered Member Three Rings int2str's Avatar
    Jan 16 2007
    2002 Audi A4 3.0 Quattro (M)
    San Diego, CA
    Lightbulb Let's play another round of "Guess that noise"!
    Welcome contestants to the 332nd round of "Guess that noise"!
    Tonight's puzzler:
    - 2002 Audi A4 3.0 Quattro 6-Speed
    - 103,000 miles on the odometer
    - Good overall condition with not-too-recent timing belt replacement
    - The clutch seems a bit worn (can make it slip if I want to), but seems to hold fine overall
    The noise:
    - When accelerating hard, a strange noise can be heard from under the hood somewhere.
    - The noise sounds similar to a slightly open window maybe, or a loose metal part - but not quite as "tinny".
    - The noise stops as soon as the clutch is pressed-in to shift.
    - The noise does not seem 100% RPM related, but only occurs under acceleration, not maintaining of speed.
    - The noise does not seem to be reproducible by just revving the engine in idle, though there may be a little bit of "the noise" as well. That one is too hard to tell really.
    - The noise does seem somewhat related to how "hard" one accelerates, not necessary what RPMs.
    - The noise can be reproduce in any lower gear, but hard to reproduce in higher gears (3+).
    Initial guesses:
    - Clutch worn past the limits?
    - Flywheel rivets? (I read that somewhere here, I think?)
    Contestants may ask any questions or have further experiments performed.
    Thanks for playing!
    2002 Audio A4
    3.0 Quattro 6-Speed
    RNS-E GPS, MP3 + Bluetooth
    19" VMR RS4 reps w/ Toyo T1R's
    LED tail lights
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: Let's play another round of "Guess that noise"!
    Seems like the throw out bearing
    -Sami-
    Jan 16 2007
    San Diego, CA
    Question Re: Let's play another round of "Guess that noise"!
    The noise only occurs when I'm "in gear", not with the clutch pedal pressed to the floor. Would this still be a symptom for the throw-out bearing?
    2002 Audio A4
    3.0 Quattro 6-Speed
    LED tail lights
    Feb 19 2007
    Charleston, SC
    Hmmm....never mind then
    -Sami-
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    throw out bearings only makes noise when you push the clutch in
    Aug 20 2007
    97 Jeep Wrangler
    are you going to the meet at the irvine spectrum on january 4th.. if so i can check out ur sound... and hopefully help you out
    May 24 2007
    Southern California
    Quote Originally Posted by downhillracer View Post
    are you going to the meet at the irvine spectrum on july 4th.. if so i can check out ur sound... and hopefully help you out
    I doubt he'd want to wait 7 months. You probably meant January.
    Kyle
    2.0L Revo GTRS Eliminator
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    worn synchros maybe
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Senior Member Two Rings BRSox307's Avatar
    Aug 16 2007
    My car (3.0 w/ 50,000 miles) makes a noise that sounds similar to what you are describing. Its been driving me crazy for over a year now and 2 dealerships and 2 other shops couldn't give me the slightest idea what it was. It could be a completely different noise than me though because mine is RPM related. Loudest being between 1500-2000 RPMs and i can reproduce it while standing still by revving up to 2500-3000 RPMs and letting go and I can hear it pretty clearly especially if i'm parked next to a wall. The best way I could describe it is a very amplified brake noise. Not the squeal, just the rubbing of the pads. Almost a hissing or a very light fast vibration... Also, I had my friend sit in my car and rev the engine while i stuck my head under the hood and walked around the car listening to see if I could find where its coming from and I couldn't hear it with my head next to the engine. However, I could hear it very clearly from the side and rear from the exhaust. Sorry I can't help answer your question, I just figured I would put this out there on the chance it's related.
    Aug 20 2007
    97 Jeep Wrangler
    Quote Originally Posted by A4natomical View Post
    haha .. oops.. edited!
