I just bought a 99 a4 and it has been nothing but problems ever since. I bought it with a broken timing belt and rebuilt the head and put all updated timing parts in. All was good besides the oil light came on, so i replaced the oil pressure sending unit. the light still came on, So i pulled the pan and it was a little sludged but the pickup was not clogged. I bought a new oil pump with pickup and replace it today, but it still comes on. I put an oil pressure gauge in place of the the temperature sender. Before when it was cold i was getting at the most 40 psi at the most then when it warmed up it wouldnt go above 20 and at idle it was around 10psi. So when i replaced the pump and first started it shot up to 80 - 90 psi. at idle its around 20 psi and cruisin around 30-40 psi. I checked the wire going from the sender to the connection in the ecu box with a continuity tester while wiggling the harness and it never lost broke its connection. What do you guys think i should test now. This thing is pissing me off and i only bought it for a good daily driver since my nissan eats way too much gas. please help Im lost and dont know where to go from here. Yes i searched and nothing matched my cituation.
