Results 1 to 10 of 10
    Established Member Two Rings Shaboink's Avatar
    Oct 03 2008
    Las Vegas, NV
    Rear Sway bar and Springs
    I just wanted to check with the know-it-alls of AZ, if I get a neuspeed rear sway bar off an RS4 will it fit? Also, I could be getting a set of H&R springs off it would they be any good on an A4? Any input is appreciated.
    Veteran Member Four Rings whartung's Avatar
    Feb 01 2007
    Re: Rear Sway bar and Springs
    the springs are probably the wrong tension for your car. the front end of the rs4 is heavier cause of the V8 than your A4 is.
    Sold: 2005.5 Sprint Blue Pearl Audi S4 Sedan 6MT
    Corsa w/ 12" Resonators - Vogt GT's - Trexturk Catless Downpipes - JHM Tuned - JHM SS - JHM Intake Spacers - JHM/Apikol Rear Differential Mount - JHM LWCP - K&N - RS4 Sway - Blackout Grille - ClearCornered and Blackedout Headlights - Xeonmatch - ECS Snub
    Oct 03 2008
    Las Vegas, NV
    BTW I drive an 08 FWD and the RS4 is an 07 (If the year even matters)
    Oct 03 2008
    Las Vegas, NV
    I figured the springs were a no go but does anyone know about the rear sway bar. I know the rs4 bar is good to go but what about a neuspeed one?
    Oct 03 2008
    Las Vegas, NV
    Nevermind I just found it on their website and you have to weld on the subframe to install the bar. Looks like I'm on the the hunt for a stock RS4 rear sway bar. :/
    Active Member Four Rings juggernaut201's Avatar
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    ecstuning.com or performancecafe.com has them for like 150 i believe
    Stage 3 Forum Advertiser Four Rings
    Apr 01 2004
    Orange County, CA
    Quote Originally Posted by KMSprechen View Post
    On the contrary, the welding part is totally optional. Neuspeed took the extra step to create braces to strengthen the sway bar mounts. These braces help prevent the OEM sway bar mounts from breaking under the pressure of stiffer sway bars.
    I've never seen OEM mounts break on a B7 before, but have had it happen on other cars, after years of spirited driving.
    This welding is actually very simple... once you've installed this, all you have to do is bring it to a muffler shop w/ a 4 post lift and it takes all but 5 minutes and $20!
    Of course, you can also choose not to install the included brace.
    Dec 12 2008
    06' A4 2.0T 6MTQ
    Jersey
    post the link of this rs4 neuspeed sway
    Oct 03 2008
    Las Vegas, NV
    I was actually miss informed the rear sway is from H&R. So once again anyone know if it'll fit?
    Nov 12 2007
    Grand Junction, CO
    It should.
