Results 1 to 37 of 37
    Veteran Member Four Rings HIERLEVELZ's Avatar
    Apr 16 2007
    Queens
    MAF sensor question!
    So I upgraded my Unitronics software to the 630cc file and swapped out the injectors and changed the MAF sensor housing to a VR6 one. The minute is start the car and plug in the maf the car dies. I've been driving the car w/o the harness plugged in. I decided to remove the MAF sensor and take a look at it and this is what i saw;
    Do you guys see whats wrong in this picture??
    BetaAlphaTau Member # 31
    2003 A4 1.8TQM
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: MAF sensor question!
    Nothing. I have a good sensor right here and it looks the same.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 16 2007
    Queens
    So the B6's dont have the heating element?
    2003 A4 1.8TQM
    Mar 21 2006
    Lakeland, FL.
    Nope. I'd check for a vacuum leak, charge hose off, or the MAF is bad.
    I'm back bitches!
    Apr 16 2007
    Queens
    Where did you get a good sensor w/o the housing?
    2003 A4 1.8TQM
    Apr 16 2007
    Queens
    damn i asked the guys at Uni to give me a mafless file but I was told they couldnt because of my model ecu. Not sure what that meant but it would have avoided this bad maf bs.
    2003 A4 1.8TQM
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Nothing wrong with the picture, turbo cars do not have a resistor in the MAF element.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    MAFless tunes suck ass
    Apr 16 2007
    Queens
    Quote Originally Posted by 400HPA4 View Post
    Well that would explain why the vr6 sensor had the element and mine didnt. I have a feeling the harness has a break in it. I would intermiitently get the ESP light turn on and off while driving. Any of you had any issues with the harness?
    I am by no means an electrical person, can you guys walk me thru testing the harness for breaks.
    2003 A4 1.8TQM
    Apr 16 2007
    Queens
    Ok another silly question. What is the orientation of the MAF housing. Does the arrow on the housing point forward or backwards when installed. OK i answered my own question.
    2003 A4 1.8TQM
    Mar 21 2006
    Lakeland, FL.
    Arrow shows the direction of airflow.
    I'm back bitches!
    Veteran Member Three Rings youngspeed's Avatar
    Jan 15 2005
    RS4 Avant, A4 1.8TQM Avant 05, EVO X 08
    Spot marked X
    Try running the stock sensor with vr6 housing
    SQ5 B8 white
    REVO STG 1+ SINGLE PULLEY,APR CPS, APR 3.0T CARBON FIBER INTAKE, 034 THROTTLE BODY SILICON HOSE, 034 REAR ARB, 034 TRANSMISSION AND DIFF MOUNTS, KW V3 COILOVERS, AP RACING BBK, LEYO V1 PADDLE SHIFTERS.
    PAST RIDES - RS4 B7 MISANO RED. GIAC TUNED, MILLTEK.y
    2015 SUBARU WRX STI, ECUTEK TUNED.
    EVO X. ECUTEK, HKS EVERYTHING
    GTRS BT A4 1.8T TQM UNITRONIC TUNED
    A6 C5
    INTEGRA GSR
    Mar 21 2006
    Lakeland, FL.
    I think he's already running it that way.
    I'm back bitches!
    Apr 16 2007
    Queens
    Quote Originally Posted by dirtybrd View Post
    Yes I am using the stock element in the VR6 housing.
    2003 A4 1.8TQM
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    how does it run boost-wise with maf unplugged?
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Apr 16 2007
    Queens
    Part throttle particularly when cold it runs a little rough but once its warmed up it seems fine. If I connect the MAF then it will die immediately. But I know its not running 100% with the MAF unplugged.
    2003 A4 1.8TQM
    Mar 21 2006
    Lakeland, FL.
    Any updates?
    I'm back bitches!
    Apr 16 2007
    Queens
    Shit man I went to the store to get some MAF cleaner only to have my MAF housing fall off(removed it earlier and didnt tighten it up properly) the car behind me ran right over the god damn thing. So now im searching for another VR6/TT225 housing.
    2003 A4 1.8TQM
    Mar 21 2006
    Lakeland, FL.
    That sucks.
    I'm back bitches!
    Apr 16 2007
    Queens
    Yeah man it does im hoping someone here on the board has a 3" maf housing for sale.
    2003 A4 1.8TQM
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Quote Originally Posted by HIERLEVELZ View Post
    PMed
    Apr 16 2007
    Queens
    Ok so I got a new maf housing and i sprayed the element with MAF cleaner but im not convinced the maf is faulty. I think i may have a short in my wiring. Any electrical gurus have a DIY for performing this test. I'm a mechanical engineer I hate wiring diagrams and anything electrical.
    2003 A4 1.8TQM
    Mar 21 2006
    Lakeland, FL.
    Any wiring issue would throw a open or short to ground code.
    I'm back bitches!
    Apr 16 2007
    Queens
    ok then im gonna go scan the car quickly and report back!
    2003 A4 1.8TQM
    Mar 21 2006
    Lakeland, FL.
    Do you have a CEL?
    I'm back bitches!
    Apr 16 2007
    Queens
    Yes I have a cel from the MAF being disconnected. The car runs fine with it disconnected once its warmed up. The reason why I think there is a short in the harness is because I previoulsy had a Carbonio intake and the maf sensor housing was clocked toward the engine which put a lot of stress on the wires. I would get the esp light turning on intermittently while driving or whenever i moved the intake. The MAF sensor was purchased back in April so I doubt it could have failed so quickly. Then again anything is possible.
    2003 A4 1.8TQM
    Mar 21 2006
    Lakeland, FL.
    Did you get the codes?
    I'm back bitches!
    Apr 16 2007
    Queens
    No I havent gotten the codes yet I will have them in about 15 mins;)
    2003 A4 1.8TQM
    Apr 16 2007
    Queens
    VAG-COM Version: Release 311.2-N
    Control Module Part Number: 8E0 UNI 518 BT
    Component and/or Version: 1.8L R4/630 G01 0003
    Software Coding: 0016501
    Work Shop Code: WSC 00210
    1 Fault Found:
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 002 - Lower Limit Exceeded
    2003 A4 1.8TQM
    Mar 21 2006
    Lakeland, FL.
    Sound bad. Is that after you installed it again and cleared the codes?
    I'm back bitches!
    Apr 16 2007
    Queens
    I'm not sure.....If it werent so cold out I would install it again and clear the codes and then check for a cel. I'll have to do it first thing in the morning.
    2003 A4 1.8TQM
    Mar 21 2006
    Lakeland, FL.
    Cool
    I'm back bitches!
    Apr 16 2007
    Queens
    So I installed the MAF and checked the g/s with VAGcom and it was right around 4g/s at idle which is within range. Car actually idled pretty good and didnt die like normal. I even took it for a ride and no issues. So I am even more confused. But if it stays like this and doesnt give me any issues then I wont be bothered.
    2003 A4 1.8TQM
    Mar 21 2006
    Lakeland, FL.
    Same MAF with out you changing anything?
    I'm back bitches!
    Apr 16 2007
    Queens
    Yeah didnt change a thing. Im thouroughly confused.
    2003 A4 1.8TQM
    Jun 30 2007
    Raleigh, NC
    sounds like loose wires to me. probably got pulled around and possibly a little messed up from being twisted in such a weird way.
    and greg - what makes you say MAFless tunes suck? we all seem to be doing pretty well....
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Apr 16 2007
    Queens
    Quote Originally Posted by B6Lovin View Post
    Yeah I think its loose or broker wiring. Havent figured out how to test it just yet. Dont quite know the pinouts. I mean I know the pinouts to test the MAF but i dont know how to identif the pinouts on the ecu harness.
    2003 A4 1.8TQM
