Results 1 to 12 of 12
    Senior Member Two Rings starfriend's Avatar
    Oct 17 2007
    A4 GTRS
    Norway
    Changed my split-r from hybird to 100% Bov, no my car idles like shit.
    Yello!
    I clogged my TIP and set my splitr to pure bov, and now my car wont start, not a problem, easy fix i can change it back. But can anyone explain the reason to me? figured i pulled something when i was down there, but its all good!
    peeeeaacccee!
    A4/B6-2001 [Eurospec]
    430cc Genesis //GTRS// REVO //ATP// CUSTOM 3" EXHAUST w/ Magnaflow Mufflers //BSR OPTIFLOW INTAKE// FORGE SPLIT-R //Neuspeed Xtreme TIP// Racetec FMIC //Hitachi E//
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: Changed my split-r from hybird to 100% Bov, no my car idles like shit.
    Sounds like it might be opening at idle.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Oct 17 2007
    A4 GTRS
    Norway
    cannot for the life of me figure why... should be installed correctly... and its set to medium (like 25 of 52 clicks)..... so idle should be just perfect afaik.
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    too much gas and no where near enough air. thats a no-go unless u have a FMIC
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Oct 17 2007
    A4 GTRS
    Norway
    well, i do have a FMIC. i thought btw that bov should only affect the car when it was discharging (let of the throttle). I tried the car for a short test and it ran like hell, backfiring and everything under acceleration. Anyone up for explaning it so i can take some wisdom from this? :)
    Saint Cloud, Fl
    If you run full BOV with the splitter you have to switch around the ports. Block of the horn side with the supplied block off and put the horn on the recirculation side
    instagram ------------> low_enforcement
    Oct 17 2007
    A4 GTRS
    Norway
    Quote Originally Posted by 7speed View Post
    I totally did. The Pipe previously going into the TIP was replaced with the BOV open thingie. And the other port blocked, and the one in the bottom going to the fmic pipe.. Shoult i should be all cool.
    Saint Cloud, Fl
    you have already done it ? or you just did ?
    Oct 17 2007
    A4 GTRS
    Norway
    i did this in the process, earlier today.. when i actually changed from hybird to bov. I havent changed anything since then, will be installing to full recirc again tomorrow.. i just dont quite understand why the car acted as it did
    Saint Cloud, Fl
    oh okay
    Oct 17 2007
    A4 GTRS
    Norway
    heh, strange huh? :) thanks for your help anyways!! :):)
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by yung turbo View Post
    What are you talking about? A BOV and FMIC have abolutely nothing in common other then both being parts in a turbo car.
    I'm back bitches!
