Results 1 to 40 of 63
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Exclamation HELP! Jim is stuck in Lexington, KY
    Jim(AZ Moderator), aka "onemoremile" is 'stranded' 20 mins outside of Lexington, KY.
    Can anybody in the area help him out?
    Known issue: Flashing CEL due to a misfire.
    Probable fix: Ignition control module, probably not the coil/plug/injector
    Feel free to give him a call if you can help.
    Here's his #616-915-.... - I'm posting this with his permission. I can't go get him or help him in person, so I'm hoping somebody from the community can help him out.
    Thanks in advance.
    EDIT: He's driving the 99.5 Avant 1.8T. Actual CEL/DTC is unknown. If you have VAG-Com or tools, I can walk you through the repair, or almost any other tech advice.
    Veteran Member Four Rings Tifun's Avatar
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Indianapolis Indiana
    Re: HELP! Jim is stuck in Lexington, KY
    have him get on louisvillevw.org and post. those folks are good people there.
    Jun 21 2007
    99.5 A4, 08 Mazda3
    i'll post a thread for him....
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Tifun View Post
    ... He's on his way to his mom's house now.
    EDIT: Thanks. Feel free to hand out his number, he said he doesn't care.
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Cool. I posted a thread quoting your post.
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Which side of lexington is he on? I am in Louisville which if he is on the east side isnt tooterribly far.
    Feb 27 2005
    North Wales, PA
    I can create havoc in the b5 forums...no one is looking
    May 22 2008
    St Clair Shores, MI
    Im not very far either, about 2 hours away. Does he need help yet tonight, like ASAP cuz by the time I got details, directions, and tools it would be kind of late time wise. I could come up tomorrow early if that would help. I dont have VAG, but I have an OBD-2 scanner. Let me know.
    13 S4 Monsoon Gray - 6MT l sports diff l Nappa l Atlas l EPL Stg2
    DP l MercRacing HX l iAbed TB l Sach's Xtend l AWE Track/Touring w/ res DPs l 034 Xbrace & drivetrain mounts l P3 Track
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I believe he said he was 20mins NorthWest of Lexington. Give him a call if you could help. I'm sure he's willing to work something out either tonight or tomorrow.
    I will say this, it did sound like he needed help tonight, it sounded like his car was not very driveable.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by Poopie View Post
    And the B5 S4, and the B6 A4... now louisvillevw.org
    May 22 2008
    St Clair Shores, MI
    Im meeting up with him with the part.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by SpoolinPelican View Post
    thank you, Jim sent me a text saying you were on your way.
    Registered Member Three Rings volks88's Avatar
    May 06 2007
    stg3 s4,02 C32 AMG,88 325IS
    lexington,ky/fond du lac,wi
    this is Brad. i talked with jim tonight. are you in fact getting him this tonight? lmk as i was about to go get one and take it out to him but if you got it cool
    May 22 2008
    St Clair Shores, MI
    Yea, I got it to him a little bit ago.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Jim's text to me said:
    "Got the part"
    "AZ members are good people"
    "I am very impressed"
    So it sounds like good reviews
    May 06 2007
    just talked with him and it's not it. im running vag com out in the a.m.
    May 22 2008
    St Clair Shores, MI
    I was afraid of that.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    well, dammit. Did it help at all?
    Coil, plug, injector, wiring... ?
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    I love AZ, thats why i am not afraid on going on a road trip through the USA, couse i know that there will be a member somewhere around to lend a hand.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    First off - you guys rock. I don't have the words to tell you how much this is appreciated.
    I installed the ICM in the waffle house parking lot and it was perfect for about 10 minutes. Then got the WRX machine gun sound and flashing CEL. Although we had two cars (mine and an 06 Outback wagon) we also had a ton of presents, three people, and my 100 pound dog. We just soldiered on and made it eventually. For the last 30 minutes it drove perfectly.
    When I left home the car was perfect even at WOT. Just South of Indy I hit a big puddle and bump on the freeway and it started stuttering above 7 psi. I had this problem a few years ago and the only thing that fixed it was replacing the PCV system. I kept it under 0-5 psi and it drove just fine. It wasn't until the drive today from Louisville to Mt. Olivet that it started missing so badly. The problem is exactly like a bad ICM. I've had a couple go bad so am familiar with the symptoms.
    It drove perfectly for a few minutes then missed badly for a half hour, then back to perfect for the rest of the drive. I've got a 7 hour drive home tomorrow (or whenever it works well enough to make it) and can't risk it going bad again.
    I'll see if my folks have tools so I can pull the plugs but they don't have much here. They have a house in Michigan and are only down here for a year to minister 3 churches so they didn't bring much more than the basics like furniture and dishes.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    I was going to give you the shirt off my back but you were wearing the same shirt. Guess the grey AZ hoody is pretty popular.
    Thank you again. Be sure to PM me your address so that I can send that part back to you when I get home.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    My cell is 616-915-3369. Reception is spotty here so a text may work best. I've subscribed to this thread so it should alert my cell when someone posts.
    Thanks again guys. This has been a very rough few months and your help gives me hope.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    Current location is 701 main street, mt olivet, ky 41064.
    Jim
    I Do Werk.
    May 22 2008
    St Clair Shores, MI
    Quote Originally Posted by onemoremile View Post
    No problem, I know how it is to be stranded. Just glad to help, well tried too. Hope all goes well! Oh, sent a pm too
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    May 06 2007
    i'll bring a small toolbox full of the hand tools you should need. i'll probably be heading out about 8:30 a.m.
    Feb 27 2005
    North Wales, PA
    damn, sounds like a wiring issue. physically check all the fuses to make sure they are ok. best of luck man. I'm sure you'll figure it out.
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Brad, again thanks for helping Jim out. As well as SpoolinPelican, I knew you guys could help take care of this. I've been helped out enough by your community. It's one I miss lol, folks aren't this helpful up by my area.
    Mar 09 2004
    nw michigan.
    Fuses are fine. It seems to be dependent on load but still inconsistent. If it made sense I would have figured it out by now.
    Jim
    I Do Werk.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Does your car have a MAP sensor? I know it's still AEB, but it's a 99.5, so it's a goofy bastard.
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    thats a negative, ATW motor has a map, no AEB. and it wouldn't have that kind of affect.. I had my map sensor dangling for about 2 days and had to drive the car.. There was ZERO issues besides the occasional boost hitting 15 psi for a couple seconds then dropping back to 8 (was stock ecu)
    Possible fuel injector issue? just tossing ideas, i got no idea..GL with it
    Veteran Member Three Rings a4937's Avatar
    Aug 14 2008
    Ohio%20
    It is really great to see people helping others who they most likely don't even know. The world needs more people like AZ'rs.
    Sep 28 2006
    Lexington
    Wish I read this last night, cause I'm in Ashland Ky not far from lexington
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Mar 09 2004
    nw michigan.
    Cell reception is poor here so I'll give you guys the home phone number. 606-724-2542.
    It has a MAF but no MAP. The MAF is only a couple years old. The entire PCV system is 3 years old and was replaced when the forged rods went in.
    Jim
    I Do Werk.
    May 22 2008
    St Clair Shores, MI
    Figure anything out with VAG?
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Damn, AZ is such a good place. No wonder I feel home
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Veteran Member Four Rings MultiAudis's Avatar
    Mar 12 2006
    01 Allroad 6mt, 01 A4
    NoVa
    I had similar intermittent misfire issues and it ended up being the wiring connector to my MAF... I think it was the green wire had wiggled itself loose after pulling the airbox to replace the turbo. I just crimped the wire back in tightly and the misfires went away. Just a thought, and it is great to see this community come together so frequently, whether it be stolen or wrecked cars, job or family losses, or the dreaded breakdown. I love this place!
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by MultiAudis View Post
    I've done a similar repair on a few customer cars. It does seem to be the green wire most frequently.
    Mar 09 2004
    nw michigan.
    Funny you mention that since I just lost my job and family and am now broken down. This Christmas has been much more interesting than I ever wanted it to be.
    Jim
    I Do Werk.
    Veteran Member Four Rings V8S4Fun's Avatar
    Jul 22 2008
    05 S4, 95 Jetta
    Taneytown, MD
    It is fantastic to see the good in people with all the bad we always hear about. I would have helped in a second if I was close to you. Hope everything works out for ya!
    [email protected]
    2005 Silver S4
    RAI Supercharged
    Unitronic Tuned
    JHM L/W Crank Pulley
    Custom 2.5" catless DPs w/Milltek Non-Res
