Results 1 to 4 of 4
    Dec 08 2007
    Easton,PA
    rear speaker hookup?
    so i recently installed an avic f900 and im also in the process of installing a JL 12" sub i wanna run the rear speakers of avic. Where can i tap into them to run the wires to the back of the headunit? I was looking at the plug that hooks into the stock amp?
    2002 A4 1.8t 5 speed maunal-revo stage 2
    Dec 08 2007
    Easton,PA
    Re: rear speaker hookup?
    anyone?
    Veteran Member Three Rings ziggituning's Avatar
    Mar 04 2008
    04 B6 1.8T Q 6 spd
    if you are investing all that money then add some time and maybe run new rca cables to your amp, otherwise you could tap into the wires at the exit from the doors, or at the factory amp in the trunk.
    PARTS FOR SALE: LW Crank Pulley, OEM injectors, ABT rep grill, OEM Intercooler, PM me.
    For your OEM HID D1S/D2S/D3S and HID conversion [Headlights/Foglights], and Interior/Exterior LED needs, send me a PM![/SIZE]
    Established Member Two Rings ExCarpi's Avatar
    Apr 06 2008
    2005 A4 1.8T 6sp
    Minneapolis, MN
    http://www.audizine.com/forum/showthread.php?t=228813
    check this out and see if it helps. Otherwise post back and I will try to help.
    I just ran wires from my headunit back to the rear amp harness and tapped into the rear speakers there.
    It sounds 100 times better than with an aftermarket HU and stock amp.
    At the same time you can run your power and remote wire for the amp to power your JL sub.
    Doesn't take too much time.
    APR TIP, APR 1+, TT injectors, RaceTec FMIC, JHM Extra short throw shifter (45% reduction), ER Test Pipe, 19" OZ Ultraleggeras, B5S4 Front Calipers, Adam's Rotors with black hubs, Hawk HPS, PSS9 coilovers, Hotchkis Sways, clear corners, tint, Magnaflow Exhaust, Podi pod with SW boost gauge.
